N
Nextcloud version: 16.01
Operating system and version: CentOS 7.6
Apache or nginx version:NGINX 1.16
PHP version: 7.3
My logs are showing a lock issue when uploading very large files. In this instance, just over 100GB. Smaller, but still large files (43GB) seem to work without issue. I’m looking for some pointers of where to look for more information to resolve this. I have plenty of disk space, I believe. Both data and tmp directories are on NFS mounts with more than 10TB free space.
Thanks in advance!
Scenario: Uploading a file > 100GB to a drop share.
- Create share
- Mark share as drop, upload only
- Upload file larger than 100GB
"reqId": "ttsPtMGyWM1h3rMHmlsG",
"level": 3,
"time": "2019-05-21T08:39:24+00:00",
"remoteAddr": "XXX.XXX.XXX.XXX",
"user": "--",
"app": "no app in context",
"method": "PUT",
"url": "\/public.php\/webdav\/vm_diskimage.qcow2",
"message": {
"Exception": "OCP\\Lock\\LockedException",
"Message": "\"files\/aef6206389df1df3ffd0825b208a83e0\" is locked, existing lock on file: none",
"Code": 0,
"Trace": [
"file": "\/nextcloud\/install\/path\/lib\/private\/Files\/Storage\/Common.php",
"line": 779,
"function": "changeLock",
"class": "OC\\Lock\\MemcacheLockingProvider",
"type": "->",
"args": [
"files\/aef6206389df1df3ffd0825b208a83e0",
2
"file": "\/nextcloud\/install\/path\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php",
"line": 615,
"class": "OC\\Files\\Storage\\Common",
"type": "->",
"args": [
"files\/Client Uploads\/vm_diskimage.qcow2",
2,
"__class__": "OC\\Lock\\MemcacheLockingProvider"
"line": 615,
"class": "OC\\Files\\Storage\\Wrapper\\Wrapper",
"type": "->",
"args": [
2,
"line": 615,
"type": "->",
"args": [
2,
"line": 615,
"type": "->",
"args": [
2,
"file": "\/nextcloud\/install\/path\/lib\/private\/Files\/View.php",
"line": 1968,
"type": "->",
"args": [
2,
"file": "\/nextcloud\/install\/path\/apps\/dav\/lib\/Connector\/Sabre\/Node.php",
"line": 392,
"class": "OC\\Files\\View",
"type": "->",
"args": [
"\/vm_diskimage.qcow2",
2
"file": "\/nextcloud\/install\/path\/apps\/dav\/lib\/Connector\/Sabre\/File.php",
"line": 241,
"class": "OCA\\DAV\\Connector\\Sabre\\Node",
"type": "->",
"args": [
2
"file": "\/nextcloud\/install\/path\/apps\/dav\/lib\/Connector\/Sabre\/Directory.php",
"line": 156,
"function": "put",
"class": "OCA\\DAV\\Connector\\Sabre\\File",
"type": "->",
"args": [
null
"file": "\/nextcloud\/install\/path\/3rdparty\/sabre\/dav\/lib\/DAV\/Server.php",
"line": 1096,
"function": "createFile",
"class": "OCA\\DAV\\Connector\\Sabre\\Directory",
"type": "->",
"args": [
"vm_diskimage.qcow2",
null
"file": "\/nextcloud\/install\/path\/3rdparty\/sabre\/dav\/lib\/DAV\/CorePlugin.php",
"line": 525,
"class": "Sabre\\DAV\\Server",
"type": "->",
"args": [
null,
null
"function": "httpPut",
"class": "Sabre\\DAV\\CorePlugin",
"type": "->",
"args": [
"absoluteUrl": "https:\/\/transfer.newestech.com\/public.php\/webdav\/vm_diskimage.qcow2",
"__class__": "Sabre\\HTTP\\Request"
"__class__": "Sabre\\HTTP\\Response"
"file": "\/nextcloud\/install\/path\/3rdparty\/sabre\/event\/lib\/EventEmitterTrait.php",
"line": 105,
"function": "call_user_func_array",
"args": [
"__class__": "Sabre\\DAV\\CorePlugin"
"httpPut"
"line": 479,
"function": "emit",
"class": "Sabre\\Event\\EventEmitter",
"type": "->",
"args": [
"method:PUT",
"line": 254,
"function": "invokeMethod",
"type": "->",
"args": [
"file": "\/nextcloud\/install\/path\/apps\/dav\/appinfo\/v1\/publicwebdav.php",
"line": 107,
"function": "exec",
"type": "->",
"args": []
"file": "\/nextcloud\/install\/path\/public.php",
"line": 79,
"args": [
"function": "require_once"
"File": "\/nextcloud\/install\/path\/lib\/private\/Lock\/MemcacheLockingProvider.php",
"Line": 129,
"CustomMessage": "--"
"userAgent": "Mozilla\/5.0 (X11; Fedora; Linux x86_64) AppleWebKit\/537.36 (KHTML, like Gecko) Chrome\/66.0.3359.170 Safari\/537.36",
"version": "16.0.1.1"
There were no errors in the nginx errors log.
