[/details]
Nextcloud version 18.0.3.0
Operating system and version (Whatever comes with NextCloudPi_RPi_03-28-20.img)
PHP version (eg, 7.1):
Need help configuring ddclient using FreeDNS. I installed using sudo apt-get install ddclient -y . But itâs not clear how I should fill out the /etc/ddclient.conf file.
Specifically, what protocol should I specify if Iâm using FreeDNS? âfreednsâ wasnât an option during install so I chose dyndns2 not knowing what else to do.
Many examples that I see say I should be adding these lines to the top of the file, but I donât really know what they do:
use=web, web=myip.dnsomatic.com
ssl=yes
My current ddclient.conf file looks pretty empty:
Configuration file for ddclient generated by debconf
/etc/ddclient.conf
protocol=dyndns2
protocol=freedns
use=if, if=wlan0
server=freedns.afraid.org
login=[login]
password=â[password]â
friedmanarchives.mooo.com
And when I run a âservice ddclient statusâ command I get the following errors:
pi@nextcloudpi:~ $ service ddclient status
â ddclient.service - LSB: Update dynamic domain name service entries
Loaded: loaded (/etc/init.d/ddclient; generated)
Active: active (running) since Thu 2020-08-20 06:55:33 BST; 1h 45min ago
Docs: man:systemd-sysv-generator(8)
Process: 660 ExecStart=/etc/init.d/ddclient start (code=exited, status=0/SUCCESS)
Tasks: 1 (limit: 3862)
CGroup: /system.slice/ddclient.service
ââ879 ddclient - sleeping for 280 seconds
Aug 20 08:25:36 nextcloudpi ddclient[3735]: WARNING: file /var/cache/ddclient/ddclient.cache, line 3: Invalid Value for keyword âipâ = ââ
Aug 20 08:25:36 nextcloudpi ddclient[3739]: WARNING: skipping update of friedmanarchives.mooo.com from to 192.168.86.122.
Aug 20 08:25:36 nextcloudpi ddclient[3739]: WARNING: last updated but last attempt on Thu Aug 20 08:20:36 2020 failed.
Aug 20 08:25:36 nextcloudpi ddclient[3739]: WARNING: Wait at least 5 minutes between update attempts.
Aug 20 08:30:37 nextcloudpi ddclient[3798]: FAILED: updating friedmanarchives.mooo.com: ERROR: Address 192.168.86.122 has not changed.: unexpected status ()
Aug 20 08:35:37 nextcloudpi ddclient[3807]: WARNING: file /var/cache/ddclient/ddclient.cache, line 3: Invalid Value for keyword âipâ = ââ
Aug 20 08:35:37 nextcloudpi ddclient[3811]: FAILED: updating friedmanarchives.mooo.com: ERROR: Address 192.168.86.122 has not changed.: unexpected status ()
Aug 20 08:40:37 nextcloudpi ddclient[3950]: WARNING: skipping update of friedmanarchives.mooo.com from to 192.168.86.122.
Aug 20 08:40:37 nextcloudpi ddclient[3950]: WARNING: last updated but last attempt on Thu Aug 20 08:35:37 2020 failed.
Aug 20 08:40:37 nextcloudpi ddclient[3950]: WARNING: Wait at least 5 minutes between update attempts.
pi@nextcloudpi:~ $
If I wait an hour these errors donât seem to grow.
Is this the first time youâve seen this error? (Y/N): Yes
See above.
[No idea where to find that]
PASTE HERE
pi@nextcloudpi:/var/log/apache2 $ more error.log
[Thu Aug 20 00:00:02.530769 2020] [ssl:warn] [pid 903:tid 3069497872] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Thu Aug 20 00:00:02.532126 2020] [mpm_event:notice] [pid 903:tid 3069497872] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1d configured -- resuming normal operations
[Thu Aug 20 00:00:02.532150 2020] [core:notice] [pid 903:tid 3069497872] AH00094: Command line: '/usr/sbin/apache2'
[Thu Aug 20 01:14:31.468760 2020] [authz_host:error] [pid 2364:tid 2763789344] [client 192.168.86.55:52414] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unab
le to get the remote host name
[Thu Aug 20 05:21:26.552618 2020] [authz_host:error] [pid 2364:tid 2763789344] [client 192.168.86.55:55468] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unab
[Thu Aug 20 06:55:08.540689 2020] [proxy_fcgi:error] [pid 2364:tid 2763789344] [client 192.168.86.55:55468] AH01067: Failed to read FastCGI header
[Thu Aug 20 06:55:08.540780 2020] [proxy_fcgi:error] [pid 2364:tid 2763789344] (104)Connection reset by peer: [client 192.168.86.55:55468] AH01075: Error dispatching request to :4443:
[Thu Aug 20 06:55:10.182210 2020] [mpm_event:notice] [pid 903:tid 3069497872] AH00491: caught SIGTERM, shutting down
[Thu Aug 20 06:55:33.520856 2020] [ssl:warn] [pid 816:tid 3069669904] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Thu Aug 20 06:55:33.560690 2020] [ssl:warn] [pid 923:tid 3069669904] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
[Thu Aug 20 06:55:33.566775 2020] [mpm_event:notice] [pid 923:tid 3069669904] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1d configured -- resuming normal operations
[Thu Aug 20 06:55:33.566907 2020] [core:notice] [pid 923:tid 3069669904] AH00094: Command line: '/usr/sbin/apache2'
[Thu Aug 20 06:55:37.121859 2020] [authz_host:error] [pid 927:tid 2763953184] [client 192.168.86.55:59265] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unabl
[Thu Aug 20 06:55:37.147283 2020] [authz_host:error] [pid 927:tid 2755552288] [client 192.168.86.25:54523] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unabl
