- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
Nextcloud Hub 25 Autumn (32.0.4)
TrueNAS SCALE Community Edition 25.10.1 - Goldeye
nginx/1.28.0
caddy v2.10.2
- PHP version (e.g, 8.3):
PHP 8.4.16
Not applied
Not applied
docker image linuxserver/nextcloud
No
I would to do a periodical backup. As the instance is running on ZFS, I take periodical snaphots of all the files and settings and back them up. The issue is the database. The instance is running on MariaDB. I know the official recommendation is mysqldump/mariadb-dump. However, it takes hours to do a full backup.
I am thinking about an alternative that utilizes mariadb-backup to do an incremental backup and running the following script periodically after a full backup:
#!/bin/bash
export BACKUP_DIR_IN_CONTAINER='/config/backup/2026-01-16'
ts=$(date +'%Y-%m-%d_%H-%M-%S%z')
docker exec nextcloud occ maintenance:mode --on
docker exec nextcloud-mariadb mariadb-backup --backup \
--databases="nextcloud" \
--target-dir="${BACKUP_DIR_IN_CONTAINER}/incremental-${ts}/" \
--incremental-basedir="${BACKUP_DIR_IN_CONTAINER}/base/" \
--user=ncuser \
--password="mypassword"
docker exec nextcloud occ maintenance:mode --off
Is it a viable solution? Any other thing I have missed?
Many thanks.
