[details=“Support intro”]
this is the error i get when i try to copy large files to the server using the web interface. its only alowing me to copy 450gb of the file. a little more then half the file. then it stops uploading.
[PHP] Error: Error: exif_read_data(): File not supported at /var/www/nextcloud/lib/private/Metadata/Provider/ExifProvider.php#59 at <>
OC\Log\ErrorHandler::onError() - /var/www/nextcloud/lib/private/Metadata/Provider/ExifProvider.php line 59
exif_read_data() - /var/www/nextcloud/lib/private/Metadata/MetadataManager.php line 68
OC\Metadata\Provider\ExifProvider->execute() - /var/www/nextcloud/lib/private/Metadata/FileEventListener.php line 101
OC\Metadata\MetadataManager->generateMetadata() - /var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php line 87
OC\Metadata\FileEventListener->handle() - /var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php line 251
OC\EventDispatcher\ServiceEventListener->__invoke() - /var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php line 73
Symfony\Component\EventDispatcher\EventDispatcher->callListeners() - /var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php line 88
Symfony\Component\EventDispatcher\EventDispatcher->dispatch() - /var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php line 100
OC\EventDispatcher\EventDispatcher->dispatch() - /var/www/nextcloud/lib/private/Files/Node/HookConnector.php line 118
OC\EventDispatcher\EventDispatcher->dispatchTyped() - /var/www/nextcloud/lib/private/legacy/OC_Hook.php line 106
OC\Files\Node\HookConnector->postWrite() - /var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php line 471
OC_Hook::emit() - /var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php line 398
OCA\DAV\Connector\Sabre\File->emitPostHooks() - /var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php line 151
OCA\DAV\Connector\Sabre\File->put() - /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1098
OCA\DAV\Connector\Sabre\Directory->createFile() - /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 504
Sabre\DAV\Server->createFile() - /var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPut() - /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
Sabre\DAV\Server->emit() - /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod() - /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start() - /var/www/nextcloud/apps/dav/appinfo/v1/webdav.php line 85
Sabre\DAV\Server->exec() - /var/www/nextcloud/remote.php line 171
require_once(“/var/www/nextcl … p”)
PUT /remote.php/webdav/4TB%20DRIVE/4TB%20DRIVE/SOUTHCOAST/DRIVE%20C/Program%20Files/Dell/Dell%20Data%20Protection/Access/Help/NO/Skin/Images/RatingBlue100.gif
from 192.168.1.1 by josh at 2023-01-17T00:14:31+00:00
