- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
- Nextcloud Server version (e.g., 10.14.0):
replace me
- Operating system and version (unraid 7.1.2):
replace me
- Web server and version (? Unsure how to see at this point):
replace me
- Reverse proxy and version _(cloudflared)
- PHP version (?):
- Is this the first time you’ve seen this error? (Yes):
- Yes
- after moving files to HDD and back to ssd after file system change
- aio
- yes
[Appdata is not present. Did you maybe change the datadir after the initial Nextcloud installation? This is not supported!
2025-05-14T12:48:04.927949531Z See GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
2025-05-14T12:48:04.927952813Z If you adjusted the datadir to be located on an external drive, make sure that the drive is still mounted!
2025-05-14T12:48:04.927955059Z In the datadir was found: all of the sudden as well as apache says getaddrinfo for host “nextcloud-aio-nextcloud” port 9000: Name does not resolve
2025-05-14T12:52:17.643032256Z Waiting for Nextcloud to start… ]
- Open aio
- Check logs in aio
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
