I am getting the following error in the logs constantly in the app richtextdocuments. It goes away if I select “Use Demo Server” but if I have “Use your own server” selected I get those errors and performance is reduced.
I am unable to adjust the “Allow list for WOPI requests” because when I select “Use my Own Server” " it never connects to allow the advanced settings options.
I entered the container and tried the command curl -vvv https://$NC_DOMAIN:443/hosting/discovery. My results are below. I did redact the IP address and hostname.
and I was able to get my Nextcloud AIO Docker setup to work with the separate ovh Collabora server and it works beautifully.
I am not very familiar with docker so I am not sure how to troubleshoot the Collabora docker instance. Is it possible to edit the Collabora docker instance?
