upgraded to NC 28.0.2 from 27.1.6.
Now my groufolders are gone and going to admin settings and try to set them again has no effect.
Anyone has the same problem?
Thanks
Thanks
any chance to execute the following?
sudo -u www-data php occ upgrade
sudo -u www-data php occ groupfolders:scan
sudo -u www-data php occ groupfolders:list
kind regards
Had the same issue. Groupfolders were not shown in the webgui.
That actually showed me the groupfolders.
I could fix it with restarting php-fpm with this command:
sudo service php8.1-fpm restart
Hope it helps
Hello, same problem,
restart php nothing, permissons set in groupfolders, by group see nothing like you do not have permissons … by only read permissions…
Plesk NGINX NextCloud 28.02
