Nextcloud version: 24.0.8.2
(was upgraded from NC 23 and earlier)
Operating system and version: Debian 11.5 Bullseye Linux amd64
Apache version: 2.4.54
PHP version: 7.4.30
Groupfolders app: 12.0.2
The issue we are facing:
On NC 24 web GUI in Groupfolders admin with settings/admin/groupfolders
there is an annoying glitch in wrongly displaying the allowed storage amount of the respective group folders list. The amount can be falsely displayed as more than one category below i.e. 1 GB instead of 10 GB set. However, reloading the GUI page shows the correct values again.
Is this the first time you’ve seen this error? (Y/N): unknown, presumably yes
- Select the web GUI in Groupfolders admin with
view with several group folders established before. Have a look at the storage values in the list to be prepared. - Change or adjust the value of any group folder and save this value.
- One will see several if not all values of other group folders being falsely displayed as below the value viewed before.
- Reload the browser page view and correct values should show again.
IMHO there seems to be no need for further logs and no error messages were found.
