But it worked before. The only thing I did was upgrade Nextcloud from 23.0.2 to 24.0.1.
Now I can access to group folders, but the icon is abnormal as below:
And if I use command “occ groupfolders:list” after access to docker container, I can get the groupfolder list normally.
Faced the same issue. After upgrading from 23 to 24.0.1 shared folders went missing. The root cause was that the groupfolders app got disabled during the upgrade. Enabling the app again made the shares re-appear.
Thanks, but after I try this command, it shown “groupfolders already enabled” and the problem was not solved. I tried to disable and enable it again, the problem still exist.
Hi
I had the exact same problem
I restarted php-fpm and Apache and It worked after. The web-interface displayed the same content as occ and i got the files back.
