pua
November 24, 2020, 5:12pm
1
how can I disable editing etc. at shared files/folders of a group?
I unchecked all “allow” options, but the shared folder with the testgroup can be still renamed by a user. Why?
Thank you.
Nextcloud 19.0.4
Operating System: Linux 4.4.0-193-generic x86_64
PHP: 7.3.22
thats the design of nc.
every share you get, you can rename.
addition to this you can also move every share wherever you want it.
https://apps.nextcloud.com/apps/groupfolders could be a alternative, but i would use it only if its really necessary.
pua
November 24, 2020, 5:44pm
3
Hi kinimodmeyer,
thats not true. Now found out, that even when there seems to be the option for a user to rename file /folder, its not possible. The user gets the message: “Could not rename “your folder””
PS: (I didn’t use Group folders app now)
you are right in the rename read only case, its not working.
there is a open issue for this behavior: Unable to rename read-only folder shared with me · Issue #16458 · nextcloud/server · GitHub
