Several weeks ago I upgraded my Nextcloud installation. After some adjustments I got the instance running again, but group folders are nowhere to be seen.
Symptoms:
- Group folders don’t appear in the files view.
- The group folders administration settings page is empty, only a text box and the “Create” button is visible.
- Trying to create a group folder from the group folders administration settings page results in a HTTP 500 error code (I couldn’t find the exact error in the server).
Some facts from the server:
occ
works. I can list and create group folders withocc groupfolders:list
andocc groupfolders:create test
. Still, nothing can be seen in the files or administration pages. - The data seems to be healthy in
data/__groupfolders
. - The data at the database seems healthy too. The results of some manual queries to
oc_group_folders*
tables seem to be OK. - On user login I see the error log:
Could not boot groupfolders: Class "OCA\GroupFolders\Mount\MountProvider" not found
.- I’ve seen posts mentioning that this could be caused because the
versions
app is disabled, but in my case it is enabled.
Other issues:
- This issue is causing some other issues on Android devices [1]
Any assistance will be appreciated. Thank you in advance,
Guillermo
[1] NPE when sharing files from another app to Nextcloud · Issue #11496 · nextcloud/android · GitHub
