GpxPod: Changing overlays/map versions does not work
I switched over from Maps since GpxPod seemed to be much more sophisticated.
It works reasonably well in NC 32.0.2, however changing the map type using the dropdown menu in the top right corner of the screen does nothing at all.
The default view (OpenStreetMap raster) can’t be changed to satellite view etc.
    • 32.0.2
    • replace me
    • Apache
    • replace me
    • 8.4.12
    • Yes
    • After installing the GpxPod App
    • NC Admin Menu
GpxPod works fine, but map layers can’t be switched/toggled
  1. Install GpxPod
  2. Load some folders with gpx track files in it
  3. Select a track to visualize
  4. Try to change the layer from OpenStreetMap raster to anything else, e. g. Satellite
none
none
no errors
PASTE
PASTE HERE
{    "system": {        "instanceid": "***REMOVED SENSITIVE VALUE***",        "passwordsalt": "***REMOVED SENSITIVE VALUE***",        "secret": "***REMOVED SENSITIVE VALUE***",        "trusted_domains": [            "klein-aber-fein.de",            "www.klein-aber-fein.de"        ],        "datadirectory": "***REMOVED SENSITIVE VALUE***",        "dbtype": "mysql",        "version": "32.0.2.2",        "overwrite.cli.url": "http:\/\/klein-aber-fein.de\/cloud",        "dbname": "***REMOVED SENSITIVE VALUE***",        "dbhost": "***REMOVED SENSITIVE VALUE***",        "dbport": "",        "dbtableprefix": "BGsD4_",        "mysql.utf8mb4": true,        "dbuser": "***REMOVED SENSITIVE VALUE***",        "dbpassword": "***REMOVED SENSITIVE VALUE***",        "installed": true,        "tempdirectory": "\/www\/htdocs\/w017f395\/klein-aber-fein.de\/cloud\/tmp\/",        "mail_smtpmode": "smtp",        "mail_sendmailmode": "pipe",        "mail_from_address": "***REMOVED SENSITIVE VALUE***",        "mail_domain": "***REMOVED SENSITIVE VALUE***",        "maintenance": false,        "theme": "",        "loglevel": 2,        "app_install_overwrite": [            "dashboardcharts",            "files_rightclick",            "occweb",            "maps",            "passwords"        ],        "updater.release.channel": "stable",        "default_phone_region": "DE",        "mail_smtphost": "***REMOVED SENSITIVE VALUE***",        "mail_smtpport": "25",        "mail_smtpauth": true,        "mail_smtpname": "***REMOVED SENSITIVE VALUE***",        "mail_smtppassword": "***REMOVED SENSITIVE VALUE***"    }}
  • calendar: 6.1.1
  • comments: 1.22.0
  • contacts: 8.1.1
  • contactsinteraction: 1.13.1
  • dav: 1.34.2
  • federation: 1.22.0
  • files: 2.4.0
  • files_reminders: 1.5.0
  • files_sharing: 1.24.1
  • files_trashbin: 1.22.0
  • files_versions: 1.25.0
  • firstrunwizard: 5.0.0-dev.0
  • gpxpod: 7.1.0
  • logreader: 5.0.0-dev.0
  • mail: 5.6.3
  • music: 2.4.1
  • news: 27.2.0
  • notes: 4.12.4
  • notifications: 5.0.0-dev.0
  • oauth2: 1.20.0
  • passwords: 2025.12.20
  • polls: 8.5.0
  • privacy: 4.0.0-dev.0
  • profile: 1.1.0
  • provisioning_api: 1.22.0
  • serverinfo: 4.0.0-dev.0
  • settings: 1.15.1
  • sharebymail: 1.22.0
  • support: 4.0.0-dev.0
  • survey_client: 4.0.0-dev.0
  • systemtags: 1.22.0
  • tasks: 0.17.1
  • text: 6.0.1
  • theming: 2.7.0
  • theming_customcss: 1.19.0
  • updatenotification: 1.22.0
  • viewer: 5.0.0-dev.0
  • webhook_listeners: 1.3.0
  • workflowengine: 2.14.0
  • activity: 5.0.0-dev.0 (installed 2.12.0)
  • admin_audit: 1.22.0
  • app_api: 32.0.0 (installed 32.0.0)
  • circles: 32.0.0 (installed 30.0.0)
  • cospend: 3.1.6 (installed 3.1.6)
  • dashboard: 7.12.0 (installed 7.11.0)
  • deck: 1.16.2 (installed 1.16.2)
  • encryption: 2.20.0
  • files_external: 1.24.0
  • files_rightclick: 0.15.1 (installed 0.15.1)
  • forms: 5.2.3 (installed 5.2.3)
  • hitobitologin: 1.1.0 (installed 1.1.0)
  • maps: 1.6.0 (installed 1.6.0)
  • photos: 5.0.0-dev.1 (installed 4.0.0)
  • twofactor_totp: 14.0.0
  • user_ldap: 1.23.0
  • user_status: 1.12.0 (installed 1.11.0)
  • weather_status: 1.12.0 (installed 1.11.0)
I already created a Github issue at
https://github.com/julien-nc/gpxpod/issues/85
but any temporary workaround (changing some codelines in any app file) would be much appreciated!
Thanks,
Ralph
