Gobytego Nextcloud Monitor
I have no support/technical question and have seen the support category. (Be aware that direct support questions will be deleted.)
on
Which general topic do you have
if anyone is interested i made a simple nextcloud monitor which used the serverinfo api.
found at my github
also if interested i have a few other utilities like a remote command loauncher… use this for running scripts on hundreds of servers at once. some might have a need for that too
I can confirm the Monitor works neatly, please share other scripts as well <3
