Giphy Integration does not work
  • Nextcloud AIO Server version (e.g., 29.x.x):
    • 12.2.1
Basically all containers are all up to date. After I installed Giphy integration and go to connected accounts in settings, I got the internal server error.
Here’s what’s in the log that is related
{"reqId":"A9UYILSs12HX1nTvASc8","level":3,"time":"2025-12-21T04:30:07+00:00","remoteAddr":"***SENSITIVE***","user":"***SENSITIVE***","app":"index","method":"GET","url":"/settings/admin/connected-accounts","message":"hash_hkdf(): Argument #2 ($key) cannot be empty in file '/var/www/html/lib/private/Security/Crypto.php' line 147","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/142.0.0.0 Safari/537.36","version":"32.0.2.2","exception":{"Exception":"Exception","Message":"hash_hkdf(): Argument #2 ($key) cannot be empty in file '/var/www/html/lib/private/Security/Crypto.php' line 147","Code":0,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AdminSettingsController"},"index"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AdminSettingsController","index",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"settings.adminsettings.index","section":"connected-accounts"}]},{"file":"/var/www/html/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/admin/connected-accounts"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","Line":150,"Previous":{"Exception":"ValueError","Message":"hash_hkdf(): Argument #2 ($key) cannot be empty","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Security/Crypto.php","line":147,"function":"hash_hkdf","args":["sha512",{"__class__":"SensitiveParameterValue"}]},{"file":"/var/www/html/lib/private/Security/Crypto.php","line":102,"function":"decryptWithoutSecret","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/custom_apps/integration_giphy/lib/Settings/Admin.php","line":31,"function":"decrypt","class":"OC\\Security\\Crypto","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/apps/settings/lib/Controller/CommonSettingsTrait.php","line":129,"function":"getForm","class":"OCA\\Giphy\\Settings\\Admin","type":"->","args":[]},{"file":"/var/www/html/apps/settings/lib/Controller/CommonSettingsTrait.php","line":179,"function":"formatSettings","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->","args":[[{"__class__":"OCA\\Giphy\\Settings\\Admin"}],[]]},{"file":"/var/www/html/apps/settings/lib/Controller/AdminSettingsController.php","line":56,"function":"getIndexResponse","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->","args":["admin","connected-accounts"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":204,"function":"index","class":"OCA\\Settings\\Controller\\AdminSettingsController","type":"->","args":["connected-accounts"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AdminSettingsController"},"index"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AdminSettingsController"},"index"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AdminSettingsController","index",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"settings.adminsettings.index","section":"connected-accounts"}]},{"file":"/var/www/html/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/admin/connected-accounts"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Security/Crypto.php","Line":147},"message":"hash_hkdf(): Argument #2 ($key) cannot be empty in file '/var/www/html/lib/private/Security/Crypto.php' line 147","exception":{},"CustomMessage":"hash_hkdf(): Argument #2 ($key) cannot be empty in file '/var/www/html/lib/private/Security/Crypto.php' line 147"}}
Did you by chance have it previously installed and maybe with a different api_key?
From the looks of the code, that’s the main scenario I could see causing that. Well that or migrating to a new instance under some scenarios.
You can check the current config (and delete/modify it as desired) via the command line:
occ config:list integration_giphy
config related sub-commands for occ are covered in the Admin Manual.
AIO specifics for running occ are here.
Thanks! I did reinstalled NC AIO and restoring the database. I could clear out some encrypted contents in the database by using pgAdmin with SQL queries to clear all contents related to an app. For example external share. Is on oc_appconfig table.
I couldn’t find for Giphy.
The output
docker exec -u www-data nextcloud-aio-nextcloud php occ config:list integration_giphy
    "apps": {
        "integration_giphy": {
            "types": "",
            "api_key": "***SENSITIVE INFO REMOVED***",
            "installed_version": "2.2.0",
            "enabled": "yes"
The output
    "apps": {
            "types": "",
            "enabled": "yes"
Well, I did remove the app by clicking the box to remove data upon deletion/removal. It does not help.
Found out that this is the correct SQL query
DELETE
FROM public.oc_appconfig
WHERE appid = 'integration_giphy';
And now, I’m able to configure it
