Getting problem while fixing the emoji problem on database
example
longer
example
here
Nextcloud version (eg, 12.0.2): 16.0.0
Operating system and version (eg, Ubuntu 17.04): Debian 9.9
Apache or nginx version (eg, Apache 2.4.25): nginx/1.10.3
PHP version (eg, 7.1): 7.3
Hey, Basically I was following this guide to enable the mysql 4-byte support.
Is this the first time you’ve seen this error? (Y/N):Y
When I executed the command to repair the database
sudo -u www-data php occ maintenance:repair
This is the output
 - Repair MySQL collation
     - Change row format for oc_addressbooks ...
     - Change collation for oc_addressbooks ...
In AbstractMySQLDriver.php line 125:
  An exception occurred while executing 'ALTER TABLE `oc_addressbooks` CONVERT TO CHARACTER SET utf8mb4 COLLATE utf8mb4_bin;':
  SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes
In PDOStatement.php line 143:
In PDOStatement.php line 141:
maintenance:repair [--include-expensive]
Nextcloud is still working just fine. What should I do to fix this?
Thanks,
Miguel de Carvalho
Just to say, that I am in the same situation. Have you found a solution in the meantime?
This will fix the problem :grin:. Helping while updating to nextcloud 16.0.1
