Nextcloud version (eg, 13.0.2):
Operating system and version (eg, Ubuntu 17.04):
PHP version (eg, 7.1):
The system install is on a Rock64 board with 2GB of RAM. HTOP shows the CPUs are never above 5% usage even during file transfer.
The default database installed is Mariadb.
Nextcloud transfers at something like 100Kb/sec, this is with a gigbit ethernet system and USB 3 external drive.
Is this the first time you’ve seen this error? (N):
- Login
- Upload a file from Android NC App
- Watch it transfer at like 100kb/sec.
There appears to be an error for every file transfer. Here's the last 10 or so:
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:19:26-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:17:42-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:17:26-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:16:59-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:15:19-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:14:59-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:14:46-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:13:50-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:13:35-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:13:18-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:12:54-0400|
|Error|PHP|touch(): Utime failed: Operation not permitted at /var/www/nextcloud/lib/private/Files/Storage/Local.php#202|2018-08-21T07:12:32-0400|
PASTE HERE
PASTE HERE
I started to transfer 1180 pictures from my phone using the NextCloud Android client app, each picture is about 2mb each, I started yesterday at about 8pm. It is now just about 12 hours later and there is like 480 left to go.
This is incredibly slow.
I am using the default Nextcloud installation from dietpi on a rock64 board with 2GB of RAM. The CPU is never above 5%. I am only using Nextcloud locally, behind a firewall. There is no security (not even HTTPS) setup on it as I am just testing it to see if I even want to really use Nextcloud.
Before I make a number of system changes, etc, is this normal speed for NextCloud?
