IF YOU INSTALLED FULLNEXTSEARCH 0.3.x, PLEASE READ THIS:
FullNextSearch is now FullTextSearch. However, it also means that you will need to remove all apps related to the old FullNextSearch. You should also clean the index before doing so:
$ sudo -u www-data ./occ fullnextsearch:reset
Then remove those apps:
FullNextSearch
FullNextSearch - Elastic Search
Files - FullNextSearch
And install the apps related to FullTextSearch:
Full text search
Full text search - Elastic Search
Full text search - Files
Beta 0.4
What’s new:
Pagination, so you can navigate throw all the result of your search.
Thanks for your help in the linked Thread. Is it possible to scan only one userfolder?
You post an Screenshot from the new search App. I have activated all 3 Apps, but I have the stock NC Search in NC 12.04
. Indexing: Dokumente/Arbeit Fulda/dlrg.pdf
[Elasticsearch\Common\Exceptions\ServerErrorResponseException]
{"error":{"root_cause":[{"type":"exception","reason":"java.lang.IllegalArgumentException: Ela
sticsearchParseException[Error parsing document in field [content]]; nested: TikaException[Un
able to extract PDF content]; nested: IOException[java.util.zip.DataFormatException: invalid
distance too far back]; nested: DataFormatException[invalid distance too far back];","header"
:{"processor_type":"attachment"}}],"type":"exception","reason":"java.lang.IllegalArgumentExce
ption: ElasticsearchParseException[Error parsing document in field [content]]; nested: TikaEx
ception[Unable to extract PDF content]; nested: IOException[java.util.zip.DataFormatException
: invalid distance too far back]; nested: DataFormatException[invalid distance too far back];
","caused_by":{"type":"illegal_argument_exception","reason":"ElasticsearchParseException[Erro
r parsing document in field [content]]; nested: TikaException[Unable to extract PDF content];
nested: IOException[java.util.zip.DataFormatException: invalid distance too far back]; neste
d: DataFormatException[invalid distance too far back];","caused_by":{"type":"parse_exception"
,"reason":"Error parsing document in field [content]","caused_by":{"type":"tika_exception","r
eason":"Unable to extract PDF content","caused_by":{"type":"i_o_exception","reason":"java.uti
l.zip.DataFormatException: invalid distance too far back","caused_by":{"type":"data_format_ex
ception","reason":"invalid distance too far back"}}}}},"header":{"processor_type":"attachment
"}},"status":500}
