Fulltextsearch issue not available anymore
    • 31
    • Win 10 wsl2 docker desktop
    • replace me
    • replace me
    • replace me
    • Yes
    • replace me
    • AIO
docker version
Client:
Version: 28.5.2
API version: 1.51
Go version: go1.25.3
Git commit: ecc6942
Built: Wed Nov 5 14:45:58 2025
OS/Arch: windows/amd64
Context: desktop-linux
Server: Docker Desktop 4.51.0 (210443)
Engine:
Version: 28.5.2
API version: 1.51 (minimum version 1.24)
Git commit: 89c5e8f
Built: Wed Nov 5 14:43:25 2025
OS/Arch: linux/amd64
Experimental: false
containerd:
Version: v1.7.29
GitCommit: 442cb34bda9a6a0fed82a2ca7cade05c5c749582
runc:
Version: 1.3.3
GitCommit: v1.3.3-0-gd842d771
docker-init:
Version: 0.19.0
GitCommit: de40ad0
[Hello, the fulltextsearch feature is not seen and not available, occ fulltextsearch:test fails suddendly without configurations or any changes. Thank you in advance for your help and support.]
  1. search by keywords does not working. No fulltextsearch output except files names or pahts.
PASTE HERE/var/www/html # php occ log:tail
  Level   App               Message        Time
" is not allowed (InvalidPathException) at                2025-12-30T15:24:52+00:00  st for Invalid path, "
                            .../3rdparty/icewind/smb/src/AbstractShare.php line 26
                             0. apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php line 70
                                Icewind\SMB\AbstractShare->verifyPath("temp\/\ufeff\r.txt")
                             1. apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php line 122
                                Icewind\SMB\Native\NativeShare->buildUrl("temp\/\ufeff\r.txt")
                             2. apps/files_external/3rdparty/icewind/smb/src/Native/NativeFileInfo.php line 43
                                Icewind\SMB\Native\NativeShare->rawStat("temp\/\ufeff\r.txt")
                             3. apps/files_external/3rdparty/icewind/smb/src/Native/NativeFileInfo.php line 71
                                Icewind\SMB\Native\NativeFileInfo->stat(
                             4. apps/files_external/3rdparty/icewind/smb/src/Native/NativeFileInfo.php line 98
                                Icewind\SMB\Native\NativeFileInfo->getMode(
                             5. apps/files_external/lib/Lib/Storage/SMB.php line 235
                                Icewind\SMB\Native\NativeFileInfo->isHidden(
                             6. apps/files_external/lib/Lib/Storage/SMB.php line 596
                                OCA\Files_External\Lib\Storage\SMB->getFolderContents("temp")
                             7. lib/private/Files/Storage/Wrapper/PermissionsMask.php line 131
                                OCA\Files_External\Lib\Storage\SMB->getDirectoryContent("temp")
                             8. <<closure>>
                                OC\Files\Storage\Wrapper\PermissionsMask->getDirectoryContent("temp")
                             9. lib/private/Files/Cache/Scanner.php line 457
                                iterator_to_array(Generator {})
                            10. lib/private/Files/Cache/Scanner.php line 414
                                OC\Files\Cache\Scanner->handleChildren("temp", 2, 3, 17344, true, 0, false)
                            11. lib/private/Files/Cache/Scanner.php line 323
                                OC\Files\Cache\Scanner->scanChildren("temp", 2, 3, 17344, true, -1)
                            12. lib/private/Files/Cache/Scanner.php line 587
                                OC\Files\Cache\Scanner->scan("temp", 2, 3)
                            13. lib/private/Files/Cache/Scanner.php line 599
                                OC\Files\Cache\Scanner->OC\Files\Cache\{closure}("*** sensitive parameters replaced ***")
                            14. lib/private/Files/Cache/Scanner.php line 586
                                OC\Files\Cache\Scanner->runBackgroundScanJob(Closure {}, "temp")
                            15. lib/private/Files/Utils/Scanner.php line 168
                                OC\Files\Cache\Scanner->backgroundScan(
                            16. apps/files/lib/BackgroundJob/ScanFiles.php line 50
                                OC\Files\Utils\Scanner->backgroundScan("")
                            17. apps/files/lib/BackgroundJob/ScanFiles.php line 133
                                OCA\Files\BackgroundJob\ScanFiles->runScanner("admin")
                            18. lib/public/BackgroundJob/Job.php line 61
                                OCA\Files\BackgroundJob\ScanFiles->run(null)
                            19. lib/public/BackgroundJob/TimedJob.php line 97
                                OCP\BackgroundJob\Job->start(OC\BackgroundJob\JobList {})
                            20. lib/public/BackgroundJob/TimedJob.php line 84
                                OCP\BackgroundJob\TimedJob->start(OC\BackgroundJob\JobList {})
                            21. cron.php line 170
                                OCP\BackgroundJob\TimedJob->execute(OC\BackgroundJob\JobList {})
  Error   files_antivirus   Can not open for reading. File: 66912 Account: admin Path: /admin/files/PI4 Papiers                                                       2025-12-30T15:39:51+00:00
                            variés/2020_10_28_traitement_SECU_fr/s3705_puma_version_ameli_remp.pdf
  Error   files_antivirus   RuntimeException:  at custom_apps/files_antivirus/lib/Item.php line 197        2025-12-30T15:39:51+00:00
                            0. custom_apps/files_antivirus/lib/Item.php line 78
                               OCA\Files_Antivirus\Item->getFileHandle(
                            1. custom_apps/files_antivirus/lib/Scanner/ScannerBase.php line 75
                               OCA\Files_Antivirus\Item->fread(
                            2. custom_apps/files_antivirus/lib/BackgroundJob/BackgroundScanner.php line 299
                               OCA\Files_Antivirus\Scanner\ScannerBase->scan(OCA\Files_Antivirus\Item {})
                            3. .../files_antivirus/lib/BackgroundJob/BackgroundScanner.php line 147
                               OCA\Files_Antivirus\BackgroundJob\BackgroundScanner->scanOneFile(OC\Files\Node\File {})
                            4. .../files_antivirus/lib/BackgroundJob/BackgroundScanner.php line 100
                               OCA\Files_Antivirus\BackgroundJob\BackgroundScanner->processFiles(LimitIterator {})
                            5. .../files_antivirus/lib/BackgroundJob/BackgroundScanner.php line 83
                               OCA\Files_Antivirus\BackgroundJob\BackgroundScanner->scan(100)
                            6. lib/public/BackgroundJob/Job.php line 61
                               OCA\Files_Antivirus\BackgroundJob\BackgroundScanner->run(null)
                            7. lib/public/BackgroundJob/TimedJob.php line 97
                            8. lib/public/BackgroundJob/TimedJob.php line 84
                            9. cron.php line 170
  Error   files_antivirus   Can not open for reading. File: 66913 Account: admin Path: /admin/files/PI4 Papiers                                                       2025-12-30T15:39:51+00:00
                            variés/2020_10_28_traitement_SECU_fr/DetailDesPaiements.pdf
  Error   files_antivirus   Can not open for reading. File: 66914 Account: admin Path: /admin/files/PI4 Papiers                                                       2025-12-30T15:39:51+00:00
                            variés/2020_10_28_traitement_SECU_fr/AttestationDroits.pdf
  Error   files_antivirus   Can not open for reading. File: 69014 Account: admin Path: /admin/files/PI4 Papiers variés/2022_11_Scan_documents_mirror_backup/Scanned   2025-12-30T15:39:51+00:00
                            documents/papers/20221209_0415_56/paper.1.thumb.jpg
" is not allowed (InvalidPathException) at                2025-12-30T15:39:52+00:00  st for Invalid path, "
                             8. <<closure>>
PASTE
PASTE HERE
        "one-click-instance": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "cheb.home.kg",
        "overwriteprotocol": "https",
            "localhost",
            "cheb.home.kg"
        "dbtype": "pgsql",
        "version": "31.0.9.1",
        "overwrite.cli.url": "https:\/\/cheb.home.kg\/",
        "dbport": "",
        "loglevel": 3,
        "log_type": "file",
        "log_rotate_size": 10485760,
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": 2048,
        "preview_max_y": 2048,
        "jpeg_quality": 60,
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": 30,
        "share_folder": "\/Shared",
        "htaccess.RewriteBase": "\/",
        "dbpersistent": false,
        "updatechecker": false,
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpsecure": "ssl",
        "mail_smtpauth": true,
        "DOMAIN": "cheb.home.kg"
  - activity: 4.0.0
  - admin_audit: 1.21.0
  - bruteforcesettings: 4.0.0
  - circles: 31.0.0
  - comments: 1.21.0
  - contacts: 7.3.3
  - contactsinteraction: 1.12.0
  - dashboard: 7.11.0
  - dav: 1.33.0
  - federation: 1.21.0
  - files: 2.3.1
  - files_antivirus: 6.0.7
  - files_downloadlimit: 4.0.0
  - files_external: 1.23.0
  - files_fulltextsearch: 31.0.0
  - files_pdfviewer: 4.0.0
  - files_reminders: 1.4.0
  - files_sharing: 1.23.1
  - files_trashbin: 1.21.0
  - files_versions: 1.24.0
  - firstrunwizard: 4.0.0
  - fulltextsearch: 31.0.1
  - fulltextsearch_elasticsearch: 31.0.1
  - logreader: 4.0.0
  - maps: 1.6.0
  - nextcloud-aio: 0.8.0
  - notifications: 4.0.0
  - notify_push: 1.2.1
  - oauth2: 1.19.1
  - password_policy: 3.0.0
  - photos: 4.0.0
  - privacy: 3.0.0
  - profile: 1.0.0
  - provisioning_api: 1.21.0
  - recommendations: 4.0.0
  - related_resources: 2.0.0
  - richdocuments: 8.7.7
  - serverinfo: 3.0.0
  - settings: 1.14.0
  - sharebymail: 1.21.0
  - spreed: 21.1.7
  - support: 3.0.0
  - survey_client: 3.0.0
  - suspicious_login: 9.0.1
  - systemtags: 1.21.1
  - text: 5.0.0
  - theming: 2.6.1
  - updatenotification: 1.21.0
  - user_status: 1.11.0
  - viewer: 4.0.0
  - weather_status: 1.11.0
  - webhook_listeners: 1.2.0
  - whiteboard: 1.5.0
  - workflowengine: 2.13.0
  - app_api: 5.0.2 (installed 5.0.2)
  - calendar: 5.5.6 (installed 5.5.6)
  - deck: 1.15.3 (installed 1.15.3)
  - encryption: 2.19.0 (installed 2.19.0)
  - mail: 5.5.8 (installed 5.5.8)
  - notes: 4.12.3 (installed 4.12.3)
  - tasks: 0.16.1 (installed 0.16.1)
  - user_ldap: 1.22.0 (installed 1.22.0)
/var/www/html # php occ fulltextsearch:check -vvv
Full text search 31.0.1
“search_platform”: “OCA\FullTextSearch_Elasticsearch\Platform\ElasticSearchPlatform”,
“app_navigation”: “0”,
“provider_indexed”: “”,
“cron_err_reset”: “1767073533”,
“tick_ttl”: “1800”,
“collection_indexing_list”: “50”,
“migration_24”: “1”,
“collection_internal”: “local”,
“collection_links”: “”
  • Search Platform:
    Elasticsearch 31.0.1 (Selected)
    “elastic_host”: [
    “http://elastic:********@nextcloud-aio-fulltextsearch:9200”
    “elastic_index”: “nextcloud-aio”,
    “fields_limit”: “10000”,
    “es_ver_below66”: “0”,
    “elastic_logger_enabled”: “true”,
    “analyzer_tokenizer”: “standard”,
    “allow_self_signed_cert”: “false”
  • Content Providers:
    Files 31.0.0
    “files_local”: “1”,
    “files_external”: “0”,
    “files_group_folders”: “0”,
    “files_encrypted”: “0”,
    “files_federated”: “0”,
    “files_size”: “20”,
    “files_pdf”: “1”,
    “files_office”: “1”,
    “files_image”: “0”,
    “files_audio”: “0”,
    “files_chunk_size”: “2”,
    “files_open_result_directly”: “1”
    /var/www/html # php occ fulltextsearch:test -vvv
.Testing your current setup:
Creating mocked content provider. ok
Testing mocked provider: get indexable documents. (2 items) ok
Loading search platform. (Elasticsearch) ok
Testing search platform. fail
In Test.php line 238:
[Exception]
Search platform (Elasticsearch) down ?
Exception trace:
at /var/www/html/custom_apps/fulltextsearch/lib/Command/Test.php:238
OCA\FullTextSearch\Command\Test->testLoadingPlatform() at /var/www/html/custom_apps/fulltextsearch/lib/Command/Test.php:92
OCA\FullTextSearch\Command\Test->execute() at /var/www/html/3rdparty/symfony/console/Command/Command.php:326
Symfony\Component\Console\Command\Command->run() at /var/www/html/core/Command/Base.php:213
OC\Core\Command\Base->run() at /var/www/html/3rdparty/symfony/console/Application.php:1078
Symfony\Component\Console\Application->doRunCommand() at /var/www/html/3rdparty/symfony/console/Application.php:324
Symfony\Component\Console\Application->doRun() at /var/www/html/3rdparty/symfony/console/Application.php:175
Symfony\Component\Console\Application->run() at /var/www/html/lib/private/Console/Application.php:187
OC\Console\Application->run() at /var/www/html/console.php:87
require_once() at /var/www/html/occ:33
fulltextsearch:test [–output [OUTPUT]] [-j|–json] [-d|–platform_delay PLATFORM_DELAY]
/var/www/html # sed -n ‘238p’ custom_apps/fulltextsearch/lib/Command/Test.php
throw new Exception (‘Search platform (’ . $testPlatform->getName() . ‘) down ?’);
/var/www/html #
/var/www/docker-aio # curl http://nextcloud-aio-fulltextsearch:9200/
“name” : “nextcloud-aio-fulltextsearch”,
“cluster_name” : “nextcloud-aio”,
“cluster_uuid” : “Ygm9kTPsQLO5QjCZSel1rw”,
“version” : {
“number” : “8.19.4”,
“build_flavor” : “default”,
“build_type” : “docker”,
“build_hash” : “aa0a7826e719b392e7782716b323c4fb8fa3b392”,
“build_date” : “2025-09-16T22:06:03.940754111Z”,
“build_snapshot” : false,
“lucene_version” : “9.12.2”,
“minimum_wire_compatibility_version” : “7.17.0”,
“minimum_index_compatibility_version” : “7.0.0”
“tagline” : “You Know, for Search”
related to Bug: Fulltextsearch_elasticsearch 31.0.1 needs Elasticsearch 9 ?
Solved by updating to 32 release.
nextcloud-aio-nextcloud:/var/www/html# php occ fulltextsearch:test
Testing search platform. ok
Locking process ok
Removing test. ok
Pausing 3 seconds 1 2 3 ok
Initializing index mapping. ok
Indexing generated documents. ok
Retreiving content from a big index (license). (size: 32386) ok
Comparing document with source. ok
Searching basic keywords:
  • ‘test’ (result: 1, expected: [“simple”]) ok
  • ‘document is a simple test’ (result: 2, expected: [“simple”,“license”]) ok
  • ‘“document is a test”’ (result: 0, expected: ) ok
  • ‘“document is a simple test”’ (result: 1, expected: [“simple”]) ok
  • ‘document is a simple -test’ (result: 1, expected: [“license”]) ok
  • ‘document is a simple +test’ (result: 1, expected: [“simple”]) ok
  • ‘-document is a simple test’ (result: 0, expected: ) ok
  • ‘document is a simple +test +testing’ (result: 1, expected: [“simple”]) ok
  • ‘document is a simple +test -testing’ (result: 0, expected: ) ok
  • ‘document is a +simple -test -testing’ (result: 0, expected: ) ok
  • ‘+document is a simple -test -testing’ (result: 1, expected: [“license”]) ok
  • ‘document is a +simple -license +testing’ (result: 1, expected: [“simple”]) ok
    Updating documents access. ok
    Searching with group access rights:
  • ‘license’ - - (result: 0, expected: ) ok
  • ‘license’ - [“group_1”] - (result: 1, expected: [“license”]) ok
  • ‘license’ - [“group_1”,“Group_2”] - (result: 1, expected: [“license”]) ok
  • ‘license’ - [“group_3”,“Group_2”] - (result: 1, expected: [“license”]) ok
  • ‘license’ - [“group_3”] - (result: 0, expected: ) ok
    Searching with share rights:
  • ‘license’ - notuser - (result: 0, expected: ) ok
  • ‘license’ - User number_2 - (result: 1, expected: [“license”]) ok
  • ‘license’ - User3 - (result: 1, expected: [“license”]) ok
  • ‘license’ - User@4 - (result: 1, expected: [“license”]) ok
    Removing test. ok
    Unlocking process ok
nextcloud-aio-nextcloud:/var/www/html# curl http://nextcloud-aio-fulltextsearch:9200/
“version” : {
“number” : “8.19.8”,
“build_hash” : “e34ace04b64e9bfa3f9e785b08e6d81f8efe314b”,
“build_date” : “2025-11-26T23:06:12.342148294Z”,
nextcloud-aio-nextcloud:/var/www/html# php occ fulltextsearch:check
Full text search 32.0.0
“app_navigation”: false,
“cron_err_reset”: 1767938396,
“tick_ttl”: 1800,
“collection_indexing_list”: 50,
“collection_links”:
  • Search Platform:
    Elasticsearch 32.0.0 (Selected)
    “fields_limit”: 10000,
    “elastic_host”: [
    “elastic_logger_enabled”: false,
    “allow_self_signed_cert”: false
    Files 32.0.0
    “files_local”: true,
    “files_external”: 0,
    “files_group_folders”: false,
    “files_size”: 300,
    “files_office”: true,
    “files_pdf”: true,
    “files_zip”: false,
    “files_chunk_size”: 2,
    “files_open_result_directly”: true
