Is it possible to use solr instead of elasticsearch.
Is there a installation guide.
Thx
Thx
I don’t know if this helps, but aunt G. has recommended to use the Nextant app together with Solr. I hope that is what are you looking for:
https://kenfavors.com/code/how-to-install-nextant-full-text-search-for-nextcloud/
No it doesn’t help, need it for Nextcloud 16 and 17
elasticsearch needs to much RAM for a SBC Odroid HC2.
Did you found some solution??
I’m searching for something but i found nothing
