Fresh installation with data carried over from prior installation fails
Summary
I had a working installation under Debian 12 (bookworm). I saved the installation and data, and installed new Debian 13 (trixie). I set up Apache and PHP following the old installation as much as possible. I copied in the data and config.php file from the old installation.
The new installation does not work, except that I can run some occ commands (see below). I can also run the cron task. So I conjecture the problem is something missing such as a php module.
    • nextcloud-32.0.0.tar.bz2, 'version' => '32.0.0.13'
    • Debian 13 (trixie)
    • apache2 2.4.65-2
    • n/a
    • 8.4
    • Probably. Since I have no idea what the error actually is, I cannot say.
    • I had a working installation under Debian 12 (bookworm). I upgraded to trixie, and have had this and other problems since.
    • tarball
    • no.
I get the following error message in the browser:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
I conjecture that some PHP module or other is missing. Which one? I have done:
apt -y install certbot python3-certbot-apache php-curl php-gd php-xml php-imagick php-redis redis-server php-zip php-mbstring
What am I missing?
  1. Go to any URL in the nextcloud tree.
{"reqId":"KfBe37rVIwJcvFJyhov6","level":3,"time":"2025-10-15T09:28:29-06:00","remoteAddr":"192.168.10.1","user":"charles","app":"core","method":"GET","url":"/index.php/apps/dashboard/","message":"Exception thrown: OCP\\Files\\GenericFileException","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36","version":"32.0.0.13","exception":{"Exception":"OCP\\Files\\GenericFileException","Message":"","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Files/SimpleFS/SimpleFile.php","line":60,"function":"getContent","class":"OC\\Files\\Node\\File","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSCombiner.php","line":98,"function":"getContent","class":"OC\\Files\\SimpleFS\\SimpleFile","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSCombiner.php","line":73,"function":"isCached","class":"OC\\Template\\JSCombiner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSResourceLocator.php","line":112,"function":"process","class":"OC\\Template\\JSCombiner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSResourceLocator.php","line":71,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/ResourceLocator.php","line":51,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":392,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":215,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::"},{"file":"/var/www/nextcloud/lib/private/Template/Template.php","line":115,"function":"getPageTemplate","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/public/AppFramework/Http/TemplateResponse.php","line":195,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":163,"function":"render","class":"OCP\\AppFramework\\Http\\TemplateResponse","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/Files/Node/File.php","Line":35,"message":"","exception":{},"CustomMessage":"Exception thrown: OCP\\Files\\GenericFileException"}}
{"reqId":"KfBe37rVIwJcvFJyhov6","level":3,"time":"2025-10-15T09:28:29-06:00","remoteAddr":"192.168.10.1","user":"charles","app":"core","method":"GET","url":"/index.php/apps/dashboard/","message":"Exception thrown: OCP\\Files\\GenericFileException","userAgent":"Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/140.0.0.0 Safari/537.36","version":"32.0.0.13","exception":{"Exception":"OCP\\Files\\GenericFileException","Message":"","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Files/SimpleFS/SimpleFile.php","line":60,"function":"getContent","class":"OC\\Files\\Node\\File","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSCombiner.php","line":98,"function":"getContent","class":"OC\\Files\\SimpleFS\\SimpleFile","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSCombiner.php","line":73,"function":"isCached","class":"OC\\Template\\JSCombiner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSResourceLocator.php","line":112,"function":"process","class":"OC\\Template\\JSCombiner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/JSResourceLocator.php","line":71,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/ResourceLocator.php","line":51,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":392,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->"},{"file":"/var/www/nextcloud/lib/private/TemplateLayout.php","line":215,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::"},{"file":"/var/www/nextcloud/lib/private/Template/Template.php","line":115,"function":"getPageTemplate","class":"OC\\TemplateLayout","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/Base.php","line":103,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/var/www/nextcloud/lib/private/Template/TemplateManager.php","line":129,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/var/www/nextcloud/index.php","line":90,"function":"printExceptionErrorPage","class":"OC\\Template\\TemplateManager","type":"->"}],"File":"/var/www/nextcloud/lib/private/Files/Node/File.php","Line":35,"message":"","exception":{},"CustomMessage":"Exception thrown: OCP\\Files\\GenericFileException"}}
dashboard/:1  Failed to load resource: the server responded with a status of 500 (Internal Server Error)
PASTE HERE
root@hawk:/var/www# su - www-data -c 'cd nextcloud && /usr/bin/php occ config:list system'
directory '/var/www/bin' does not exist
directory '/var/www/.local/bin' does not exist
Today is Pungenday, the 69th of Bureaucracy, 3191. Lies and slander, sire!
            "nextcloud",
            "nextcloud.localdomain",
            "localhost",
            "hawk",
            "hawk.localdomain",
            "nextcloud.curleynet.mywire.org:17800"
        "dbtype": "sqlite3",
        "version": "32.0.0.13",
        "overwrite.cli.url": "http:\/\/localhost",
        "default_phone_region": "US",
        "theme": "",
        "loglevel": 2,
        "logtimezone": "America\/Denver",
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpauth": 1,
        "mail_smtpauthtype": "LOGIN",
        "app_install_overwrite": [
            "calendar"
        "trashbin_retention_obligation": "auto, 90",
        "maintenance_window_start": 19,
        "filelocking.enabled": true,
        "redis": {
            "port": 0,
            "timeout": 0
        "versions_retention_obligation": "auto, 90"
root@hawk:/var/www#
root@hawk:/var/www# su - www-data -c 'cd nextcloud && /usr/bin/php occ app:list'
Today is Pungenday, the 69th of Bureaucracy, 3191. You are what you see.
  - activity: 5.0.0-dev.0
  - app_api: 32.0.0
  - circles: 32.0.0
  - comments: 1.22.0
  - contactsinteraction: 1.13.1
  - dashboard: 7.12.0
  - dav: 1.34.2
  - federation: 1.22.0
  - files: 2.4.0
  - files_external: 1.24.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.0
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0-dev.0
  - logreader: 5.0.0-dev.0
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - support: 4.0.0-dev.0
  - systemtags: 1.22.0
  - text: 6.0.0-dev.0
  - theming: 2.7.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - admin_audit: 1.22.0
  - encryption: 2.20.0
  - photos: 5.0.0-dev.1 (installed 2.0.1)
  - survey_client: 4.0.0-dev.0 (installed 2.0.0)
  - twofactor_totp: 14.0.0
  - user_ldap: 1.23.0
  - weather_status: 1.12.0 (installed 1.2.0)
root@hawk:/var/www#
If you still have the old installation I would recommend to perform the migration in proper way as described in Migrating to a different server — Nextcloud latest Administration Manual latest documentation
see 101: backup what and why (not how) to learn which data is important.
please review Preparing PHP — Nextcloud latest Administration Manual latest documentation
Thank you. I was not aware of that. I will be away for several days, and will try it when I get back.
I am familiar with that one. It is incomplete. I added several PHP packages to the apt install command I showed above.
You’re right. I missed adding a bunch of the required modules to the the quick reference table. Technically, they’re all there on the page somewhere, but definitely an oversight.
Fixed (probably will take a day or two to go live):
Problem solved. I ran several commands,
su - www-data -c 'cd nextcloud && /usr/bin/php occ status'
su - www-data -c 'cd nextcloud && /usr/bin/php occ maintenance:data-fingerprint'
su - www-data -c 'cd nextcloud && /usr/bin/php occ maintenance:repair'
The last one produced a lot of output that looked like it actually did something. Once that finished, I was able to use the web interface.
However, three of my apps were missing: Calendar, Contacts, and Notes. I went to Featured Apps. Those three showed versions of 0. So I disabled and re-enabled all three. They are back, and all the data is intact.
Thank you. Much better. Can you sort those by module name?
Not surprised. Those aren’t shipped apps. You’d have to carry them over from your old environment (or re-install them anew).
When migrating you have to identify all the non-default apps in your apps/ folder and make sure they get moved over.
Same goes for some manual updating and recovery processes.
Most of the packaged distribution/deploy methods (e.g. Community Docker, AIO, etc.) for Nextcloud separate the shipped apps from the other apps to make this even easier/clearer - e.g. https://docs.nextcloud.com/server/latest/admin_manual/apps_management.html#using-custom-app-directories
