My RaspberryPi 3b is running the latest NextCloudPi image.
Inside my local network everything works fine. When trying to access NextCloud from outside by setting up either freeDNS or no-ip I get the same curl error each time. Example for no-ip:
[ no-ip ] (Mon Oct 23 17:55:25 BST 2023)
Auto configuration for Linux client of no-ip.com.
Only one host [<my-noip-domain>] is registered to this account.
It will be used.
New configuration file '/usr/local/etc/no-ip2.conf' created.
Failed to enable unit: Unit /run/systemd/generator.late/noip2.service is transient or generated.
System config value trusted_domains => 3 set to string <my-noip-domain>
System config value overwrite.cli.url set to string https://<my-noip-domain>/
System config value trusted_proxies => 11 set to string 127.0.0.1
System config value trusted_proxies => 12 set to string ::1
System config value trusted_proxies => 13 set to string <my-noip-domain>
System config value trusted_proxies => 14 set to string <my-ipv4>
Setup notify_push (attempt 1/5)
✓ redis is configured
🗴 can't connect to push server: cURL error 28: Connection timed out after 30001 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://<my-noip-domain>/push/test/cookie
I can’t do port-forwarding on my router, nor can does UPNP work. Is that a requirement?
Let me know if you need any further details regarding my setup.
Thanks in advance!
