Hello from France !
I need your help to achieve my configuration qhat I’m trying to test : I want to securize my server with working with Jail.
I have :
- a FreeBSD Host 13.1 (ip=192.168.1.120) with an nginx ;
- a jail (ip=10.7.16.101) with nginx, php-fpm for Nextcloud 26 in a subdirectory /nextcloud ;
My problem is that the Nextcloud don’t works normaly…
This is the config file of the nginx of the host :
worker_processes 1;
events {
worker_connections 1024;
}http {
include /usr/local/etc/nginx/mime.types;
default_type application/octet-stream;sendfile on;
keepalive_timeout 65;
server {
listen 80;
server_name localhost;include /usr/local/etc/nginx/mime.types;
location / {
root /usr/local/www/nginx;
index index.html index.htm;
}error_page 500 502 503 504 /50x.html;
location = /50x.html {
root /usr/local/www/nginx-dist;
}location /nextcloud
proxy_set_header Host $host; #gp
proxy_set_header X-Real-IP $remote_addr;#gp
proxy_set_header X-Forwarded-Server $server_name;
proxy_pass http://10.7.16.101;
}Click to expand…
This is the config file of the nginx of the jail :
worker_processes 1;
events {
}http {
keepalive_timeout 65;upstream php-handler {
server 127.0.0.1:9000;
}map $arg_v $asset_immutable {
default “immutable”;
}server {
listen 80;
server_name 10.7.16.101;root /usr/local/www/nextcloud;
server_tokens off;
client_max_body_size 512M;
client_body_timeout 300s;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml text/javascript application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/wasm application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;client_body_buffer_size 512k;
fastcgi_hide_header X-Powered-By;include /usr/local/etc/nginx/mime.types;
types {
text/javascript js mjs;
}index index.php index.html /index.php$request_uri;
location = / {
if ( $http_user_agent ~ ^DavClnt ) {
return 302 /remote.php/webdav/$is_args$args;
}location = /robots.txt {
allow all;
log_not_found off;
access_log off;
}location ^~ /.well-known {
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }location /.well-known/acme-challenge { try_files $uri $uri/ =404; }
location /.well-known/pki-validation { try_files $uri $uri/ =404; }return 301 /index.php$request_uri;
}location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) { return 404; }
location ~ ^/(?:.|autotest|occ|issue|indie|db_|console) { return 404; }location ~ .php(?:$|/) {
rewrite ^/(?!index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|oc[ms]-provider/.+|.+/richdocumentscode/proxy) /index.php$request_uri;fastcgi_split_path_info ^(.+?.php)(/.*)$;
set $path_info $fastcgi_path_info;try_files $fastcgi_script_name =404;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;fastcgi_param modHeadersAvailable true; # Avoid sending the security headers twice
fastcgi_param front_controller_active true; # Enable pretty urls
fastcgi_pass php-handler;fastcgi_intercept_errors on;
fastcgi_request_buffering off;fastcgi_max_temp_file_size 0;
}Serve static files
location ~ .(?:css|js|mjs|svg|gif|png|jpg|ico|wasm|tflite|map)$ {
add_header Cache-Control “public, max-age=15778463, $asset_immutable”;
access_log off; # Optional: Don’t log access to assetslocation ~ .wasm$ {
default_type application/wasm;
}location ~ .woff2?$ {
expires 7d; # Cache-Control policy borrowed from.htaccess
}Rule borrowed from
.htaccesslocation /remote {
return 301 /remote.php$request_uri;
}location / {
try_files $uri $uri/ /index.php$request_uri;
}Click to expand…
This is the config file of Nextcloud :
<?php $CONFIG = array ( 'overwritehost' => '192.168.1.120', 'overwritewebroot' => '/nextcloud', 'trusted_domains' => array ( 0 => '10.7.16.101', 2 => '192.168.1.120', ), 'overwrite.cli.url' => 'http://192.168.1.120/nextcloud', 'apps_paths' => array ( 0 => array ( 'path' => '/usr/local/www/nextcloud/apps', 'url' => '/apps', 'writable' => true, ), 1 => array ( 'path' => '/usr/local/www/nextcloud/apps-pkg', 'url' => '/apps-pkg', 'writable' => false, ), ), 'logfile' => '/var/log/nextcloud/nextcloud.log', 'memcache.local' => '\\OC\\Memcache\\APCu', 'instanceid' => 'oc1lgk4z97b8', ); Click to expand...
When I try to access 192.168.1.120/nextcloud, I get some errors as the file shows.
I don’t know how to solve the errors that appear…
Any idea/Advice ?
Many thanks in advance !
