Il semble y avoir un problème depuis le 27 mars, dans le nextcloud.log j’ai une ligne :
{“reqId”:“ZgR0eO7sllBdXuH29A6qXwAAAA8”,“level”:3,“time”:“2024-03-27T19:33:13+00:00”,“remoteAddr”:“178.******.105”,“user”:“******73”,“app”:“webdav”,“method”:“PROPFIND”,“url”:“/nc/remote.php/dav/files/******73/”,“message”:“SQLSTATE[HY000]: General error: 1 cannot rollback - no transaction is active”,“userAgent”:“Mozilla/5.0 (Windows) mirall/3.12.2stable-Win64 (build 20240320) (Nextcloud, windows-10.0.22631 ClientArchitecture: x86_64 OsArchitecture: x86_64)”,“version”:“28.0.3.2”,“exception”:{“Exception”:“Doctrine\DBAL\Driver\PDO\PDOException”,“Message”:“SQLSTATE[HY000]: General error: 1 cannot rollback - no transaction is active”,“Code”:“HY000”,“Trace”:[{“file”:“/home/******nc/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php”,“line”:137,“function”:“new”,“class”:“Doctrine\DBAL\Driver\PDO\PDOException”,“type”:“::”,“args”:[[“PDOException”,[“HY000”,1,“cannot rollback - no transaction is active”]]]},{“file”:“/home/******nc/3rdparty/doctrine/dbal/src/Connection.php”,“line”:1516,“function”:“rollBack”,“class”:“Doctrine\DBAL\Driver\PDO\Connection”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/DB/ConnectionAdapter.php”,“line”:162,“function”:“rollBack”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/Files/Config/UserMountCache.php”,“line”:138,“function”:“rollBack”,“class”:“OC\DB\ConnectionAdapter”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/Files/SetupManager.php”,“line”:297,“function”:“registerMounts”,“class”:“OC\Files\Config\UserMountCache”,“type”:“->”,“args”:[[“OC\User\User”],[[“OC\Files\Mount\HomeMountPoint”]],[“OC\Files\Mount\CacheMountProvider”,“OCA\Files_Sharing\MountProvider”,“OCA\Files_Sharing\External\MountProvider”]]},{“file”:“/home/******nc/lib/private/Files/SetupManager.php”,“line”:221,“function”:“afterUserFullySetup”,“class”:“OC\Files\SetupManager”,“type”:“->”,“args”:[[“OC\User\User”],]},{“file”:“/home/******nc/lib/private/Files/SetupManager.php”,“line”:392,“function”:“setupForUser”,“class”:“OC\Files\SetupManager”,“type”:“->”,“args”:[[“OC\User\User”]]},{“file”:“/home/******nc/lib/private/Files/Mount/Manager.php”,“line”:97,“function”:“setupForPath”,“class”:“OC\Files\SetupManager”,“type”:“->”,“args”:[“/******73/files”]},{“file”:“/home/******nc/lib/private/Files/View.php”,“line”:1370,“function”:“find”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/******73/files”]},{“file”:“/home/******nc/lib/private/Files/Node/Root.php”,“line”:203,“function”:“getFileInfo”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/******73/files”,false]},{“file”:“/home/******nc/lib/private/Files/Node/LazyUserFolder.php”,“line”:47,“function”:“get”,“class”:“OC\Files\Node\Root”,“type”:“->”,“args”:[“/***73/files"]},{“function”:“OC\Files\Node\{closure}”,“class”:“OC\Files\Node\LazyUserFolder”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/home/******nc/lib/private/Files/Node/LazyFolder.php”,“line”:70,“function”:“call_user_func”,“args”:[[“Closure”]]},{“file”:“/home/******nc/lib/private/Files/Node/LazyFolder.php”,“line”:84,“function”:“getRealFolder”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/Files/Node/LazyFolder.php”,“line”:260,“function”:“__call”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“getEtag”,]},{“file”:“/home/******nc/apps/dav/lib/Connector/Sabre/Node.php”,“line”:208,“function”:“getEtag”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:},{“file”:“/home/******nc/apps/dav/lib/Connector/Sabre/FilesPlugin.php”,“line”:335,“function”:“getETag”,“class”:“OCA\DAV\Connector\Sabre\Node”,“type”:“->”,“args”:},{“file”:“/home/***nc/3rdparty/sabre/dav/lib/DAV/PropFind.php",“line”:95,“function”:“OCA\DAV\Connector\Sabre\{closure}”,“class”:“OCA\DAV\Connector\Sabre\FilesPlugin”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/home/******nc/apps/dav/lib/Connector/Sabre/FilesPlugin.php”,“line”:334,“function”:“handle”,“class”:“Sabre\DAV\PropFind”,“type”:“->”,“args”:[“{DAV:}getetag”,[“Closure”]]},{“file”:“/home/******nc/3rdparty/sabre/event/lib/WildcardEmitterTrait.php”,“line”:89,“function”:“handleGetProperties”,“class”:“OCA\DAV\Connector\Sabre\FilesPlugin”,“type”:“->”,“args”:[[“Sabre\DAV\PropFind”],[“OCA\DAV\Files\FilesHome”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:1052,“function”:“emit”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[“propFind”,[[“Sabre\DAV\PropFind”],[“OCA\DAV\Files\FilesHome”]]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:984,“function”:“getPropertiesByNode”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Sabre\DAV\PropFind”],[“OCA\DAV\Files\FilesHome”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:1662,“function”:“getPropertiesIteratorForPath”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[“files/******73”,[“{DAV:}getetag”],0]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:1647,“function”:“writeMultiStatus”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Sabre\Xml\Writer”,,“/nc/remote.php/dav/”,[“d”,“s”,“oc”,“nc”],],[“Generator”],false]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/CorePlugin.php”,“line”:346,“function”:“generateMultiStatus”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Generator”],false]},{“file”:“/home/******nc/3rdparty/sabre/event/lib/WildcardEmitterTrait.php”,“line”:89,“function”:“httpPropFind”,“class”:“Sabre\DAV\CorePlugin”,“type”:“->”,“args”:[[“Sabre\HTTP\Request”],[“Sabre\HTTP\Response”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:472,“function”:“emit”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[“method:PROPFIND”,[[“Sabre\HTTP\Request”],[“Sabre\HTTP\Response”]]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:253,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Sabre\HTTP\Request”],[“Sabre\HTTP\Response”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:321,“function”:“start”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:},{“file”:“/home/******nc/apps/dav/lib/Server.php”,“line”:373,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:},{“file”:“/home/******nc/apps/dav/appinfo/v2/remote.php”,“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:“->”,“args”:},{“file”:“/home/******nc/remote.php”,“line”:172,“args”:[“/home/******nc/apps/dav/appinfo/v2/remote.php”],“function”:“require_once”}],“File”:“/home/******nc/3rdparty/doctrine/dbal/src/Driver/PDO/PDOException.php”,“Line”:20,“Previous”:{“Exception”:“PDOException”,“Message”:“SQLSTATE[HY000]: General error: 1 cannot rollback - no transaction is active”,“Code”:“HY000”,“Trace”:[{“file”:“/home/******nc/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php”,“line”:135,“function”:“rollBack”,“class”:“PDO”,“type”:“->”,“args”:},{“file”:“/home/******nc/3rdparty/doctrine/dbal/src/Connection.php”,“line”:1516,“function”:“rollBack”,“class”:“Doctrine\DBAL\Driver\PDO\Connection”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/DB/ConnectionAdapter.php”,“line”:162,“function”:“rollBack”,“class”:“Doctrine\DBAL\Connection”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/Files/Config/UserMountCache.php”,“line”:138,“function”:“rollBack”,“class”:“OC\DB\ConnectionAdapter”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/Files/SetupManager.php”,“line”:297,“function”:“registerMounts”,“class”:“OC\Files\Config\UserMountCache”,“type”:“->”,“args”:[[“OC\User\User”],[[“OC\Files\Mount\HomeMountPoint”]],[“OC\Files\Mount\CacheMountProvider”,“OCA\Files_Sharing\MountProvider”,“OCA\Files_Sharing\External\MountProvider”]]},{“file”:“/home/******nc/lib/private/Files/SetupManager.php”,“line”:221,“function”:“afterUserFullySetup”,“class”:“OC\Files\SetupManager”,“type”:“->”,“args”:[[“OC\User\User”],]},{“file”:“/home/******nc/lib/private/Files/SetupManager.php”,“line”:392,“function”:“setupForUser”,“class”:“OC\Files\SetupManager”,“type”:“->”,“args”:[[“OC\User\User”]]},{“file”:“/home/******nc/lib/private/Files/Mount/Manager.php”,“line”:97,“function”:“setupForPath”,“class”:“OC\Files\SetupManager”,“type”:“->”,“args”:[“/******73/files”]},{“file”:“/home/******nc/lib/private/Files/View.php”,“line”:1370,“function”:“find”,“class”:“OC\Files\Mount\Manager”,“type”:“->”,“args”:[“/******73/files”]},{“file”:“/home/******nc/lib/private/Files/Node/Root.php”,“line”:203,“function”:“getFileInfo”,“class”:“OC\Files\View”,“type”:“->”,“args”:[“/******73/files”,false]},{“file”:“/home/******nc/lib/private/Files/Node/LazyUserFolder.php”,“line”:47,“function”:“get”,“class”:“OC\Files\Node\Root”,“type”:“->”,“args”:[“/***73/files"]},{“function”:“OC\Files\Node\{closure}”,“class”:“OC\Files\Node\LazyUserFolder”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/home/******nc/lib/private/Files/Node/LazyFolder.php”,“line”:70,“function”:“call_user_func”,“args”:[[“Closure”]]},{“file”:“/home/******nc/lib/private/Files/Node/LazyFolder.php”,“line”:84,“function”:“getRealFolder”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:},{“file”:“/home/******nc/lib/private/Files/Node/LazyFolder.php”,“line”:260,“function”:“__call”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:[“getEtag”,]},{“file”:“/home/******nc/apps/dav/lib/Connector/Sabre/Node.php”,“line”:208,“function”:“getEtag”,“class”:“OC\Files\Node\LazyFolder”,“type”:“->”,“args”:},{“file”:“/home/******nc/apps/dav/lib/Connector/Sabre/FilesPlugin.php”,“line”:335,“function”:“getETag”,“class”:“OCA\DAV\Connector\Sabre\Node”,“type”:“->”,“args”:},{“file”:“/home/***nc/3rdparty/sabre/dav/lib/DAV/PropFind.php",“line”:95,“function”:“OCA\DAV\Connector\Sabre\{closure}”,“class”:“OCA\DAV\Connector\Sabre\FilesPlugin”,“type”:“->”,“args”:[" sensitive parameters replaced ***”]},{“file”:“/home/******nc/apps/dav/lib/Connector/Sabre/FilesPlugin.php”,“line”:334,“function”:“handle”,“class”:“Sabre\DAV\PropFind”,“type”:“->”,“args”:[“{DAV:}getetag”,[“Closure”]]},{“file”:“/home/******nc/3rdparty/sabre/event/lib/WildcardEmitterTrait.php”,“line”:89,“function”:“handleGetProperties”,“class”:“OCA\DAV\Connector\Sabre\FilesPlugin”,“type”:“->”,“args”:[[“Sabre\DAV\PropFind”],[“OCA\DAV\Files\FilesHome”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:1052,“function”:“emit”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[“propFind”,[[“Sabre\DAV\PropFind”],[“OCA\DAV\Files\FilesHome”]]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:984,“function”:“getPropertiesByNode”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Sabre\DAV\PropFind”],[“OCA\DAV\Files\FilesHome”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:1662,“function”:“getPropertiesIteratorForPath”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[“files/******73”,[“{DAV:}getetag”],0]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:1647,“function”:“writeMultiStatus”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Sabre\Xml\Writer”,,“/nc/remote.php/dav/”,[“d”,“s”,“oc”,“nc”],],[“Generator”],false]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/CorePlugin.php”,“line”:346,“function”:“generateMultiStatus”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Generator”],false]},{“file”:“/home/******nc/3rdparty/sabre/event/lib/WildcardEmitterTrait.php”,“line”:89,“function”:“httpPropFind”,“class”:“Sabre\DAV\CorePlugin”,“type”:“->”,“args”:[[“Sabre\HTTP\Request”],[“Sabre\HTTP\Response”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:472,“function”:“emit”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[“method:PROPFIND”,[[“Sabre\HTTP\Request”],[“Sabre\HTTP\Response”]]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:253,“function”:“invokeMethod”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:[[“Sabre\HTTP\Request”],[“Sabre\HTTP\Response”]]},{“file”:“/home/******nc/3rdparty/sabre/dav/lib/DAV/Server.php”,“line”:321,“function”:“start”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:},{“file”:“/home/******nc/apps/dav/lib/Server.php”,“line”:373,“function”:“exec”,“class”:“Sabre\DAV\Server”,“type”:“->”,“args”:},{“file”:“/home/******nc/apps/dav/appinfo/v2/remote.php”,“line”:35,“function”:“exec”,“class”:“OCA\DAV\Server”,“type”:“->”,“args”:},{“file”:“/home/******nc/remote.php”,“line”:172,“args”:[“/home/******nc/apps/dav/appinfo/v2/remote.php”],“function”:“require_once”}],“File”:“/home/******nc/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php”,“Line”:135},“message”:“SQLSTATE[HY000]: General error: 1 cannot rollback - no transaction is active”,“exception”:{“errorInfo”:[“HY000”,1,“cannot rollback - no transaction is active”]},“CustomMessage”:“SQLSTATE[HY000]: General error: 1 cannot rollback - no transaction is active”}}
