Forbidden paths vs allowed paths
I found a lot of example caddy configurations forbidding specific paths like
@forbidden {
    path /.htaccess
  respond @forbidden 404
But I wonder what happens if nextcloud, the distribution or even the user introduce new paths which should also be forbidden. Nobody would remember updating the forbidden paths.
So I want to specify which path are allowed, all others forbidden.
My current definition: see below. It is not complete because I do not want to exhibit how I protect my cloud. My list might exhibit more than it should.
What I would like to know: Is there any place where nextcloud defines what is needed? Including apps? Or do I just have to allow more paths when something does not work without?
@forbidden {
   not {
      path /.well-known/*
      path /remote.php/*
      path /dist/*
respond @forbidden "Du kommst hier nicht rein" 404
If you are not using Apache, this is a known problem in the world of PHP applications. Apache is one of the only known and widely used web servers that allows configuration by the application itself. Nextcloud provides a .htaccess file for this purpose.
If you are not using Apache, I would check the NGINX configuration documentation for each major update (even if you are not using NGINX). The NGINX configuration often gives an indication of which directories/files should not be publicly accessible.
