- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
- Nextcloud-aio: version 12.5.0, Nextcloud Hub 25 Autumn (32.0.4)
- Nextcloud Hub 25 Autumn (32.0.4)
- Apache/2.4.66 (Unix)
Yes
When installing Flow (windmill) from the admin +apps menu
AIO
no
When I install Flow (windmill) from nextcloud apps, the installation process says: Error starting install of ExApp. And nc_app_flow is stuck in a restart loop. How to solve this issue?
- Install docker
sudo apt install docker-ce docker-ce-cli containerd.io docker-buildx-plugin docker-compose-plugin
sudo apt install docker-compose
sudo systemctl start docker
- Install nextcloud-aio
$ cat compose.yaml
services:
image: ghcr.io/nextcloud-releases/all-in-one:latest
init: true
restart: always
volumes:
- nextcloud_aio_data:/mnt/ncdata
ports:
- 80:80
- 8080:8080
- 8443:8443
environment:
NEXTCLOUD_DATADIR: /mnt/ncdata
volumes:
nextcloud_aio_data:
- from the AIO admin page install Docker Socket Proxy
[x] Docker Socket Proxy (needed for Nextcloud App API)
- webhook_listeners already enabled
- Enable AppAPI in the admin settings tools category
- Check deploy daemon connection and test deploy worked OK
- Installation of Flow (windmill) from the Nextcloud apps
- Admin
- + Apps
- Flow (bottom left)
- Deploy and Enable
==> was kind of removed, after “health checking” for minutes. “Error starting install of ExApp”
==> nc_app_flow is stuck in a restarting loop
nc_app_flow
$ docker logs nc_app_flow
HP_SHARED_KEY is not set. Skipping FRP configuration.
flow is already in /etc/hosts
PostgreSQL binaries found.
Starting PostgreSQL...
pg_ctl: another server might be running; trying to start server anyway
waiting for server to start.... done
server started
Waiting for PostgreSQL to start...
PostgreSQL is up and running.
ALTER ROLE
DATABASE_URL is already set to: postgresql://flow:flow@%2Fvar%2Frun%2Fpostgresql/flow?sslmode=disable
NUM_WORKERS is already set to: 24
Starting windmill in background...
Starting main command as a Python script: /ex_app/lib/main.py
Running in standalone mode
We STRONGLY recommend using at most 1 worker per container, use at your own risks
Connecting to database...
PostgreSQL version: PostgreSQL 15.15 (Debian 15.15-1.pgdg12+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 12.2.0-14+deb12u1) 12.2.0, 64-bit (windmill require PG >= 14)
OTEL settings loaded: tracing (false), logs (false), metrics (false), endpoint (None), headers defined: (false)
Database connected
2026-02-08T14:10:28.078822Z WARN windmill-common/src/server.rs:81: SMTP not configured
[DEBUG]: USERS_STORAGE_PATH= /nc_app_flow_data/windmill_users_config.json
[DEBUG]: PROJECT_ROOT_FOLDER= /
[DEBUG]: STATIC_FRONTEND_PRESENT= True
2026-02-08T14:10:28.570276Z ERROR windmill-api/src/tracing_init.rs:39: response latency=0 status=401
2026-02-08T14:10:28.635773Z ERROR windmill-common/src/error.rs:267: Internal: Not implemented in Windmill's Open Source repository @users_oss.rs:53:9 error=InternalErrLoc { message: "Not implemented in Windmill's Open Source repository", location: "users_oss.rs:53:9" }
2026-02-08T14:10:28.635810Z ERROR windmill-api/src/tracing_init.rs:39: response latency=2 status=500
2026-02-08T14:10:28.635817Z ERROR windmill-api/src/tracing_init.rs:50: response failure latency=2
[initialize_windmill]: initialize_windmill: can not change default credentials password: Internal: Not implemented in Windmill's Open Source repository @users_oss.rs:53:9
Traceback (most recent call last):
File "/ex_app/lib/main.py", line 741, in <module>
initialize_windmill()
File "/ex_app/lib/main.py", line 316, in initialize_windmill
raise RuntimeError(f"initialize_windmill: can not change default credentials password, {r.text}")
RuntimeError: initialize_windmill: can not change default credentials password, Internal: Not implemented in Windmill's Open Source repository @users_oss.rs:53:9
{"reqId":"71a9GdGdVAxZ4CQ4opi0","level":2,"time":"2026-02-08T12:45:42+00:00","remoteAddr":"","user":"--","app":"app_api","method":"","url":"--","scriptName":"console.php","message":"Failed heartbeat on http://flow:23001 for 600 times. Most recent status=0, error: cURL error 6: Could not resolve host: flow (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for http://flow:23001/heartbeat","userAgent":"--","version":"32.0.4.1","occ_command":["console.php","app_api:app:register"],"data":{"app":"app_api"}}
{"reqId":"71a9GdGdVAxZ4CQ4opi0","level":3,"time":"2026-02-08T12:45:43+00:00","remoteAddr":"","user":"--","app":"app_api","method":"","url":"--","scriptName":"console.php","message":"ExApp flow heartbeat check failed. Make sure that Nextcloud instance and ExApp can reach it other.","userAgent":"--","version":"32.0.4.1","occ_command":["console.php","app_api:app:register"],"data":{"app":"app_api"}}
{"reqId":"UYZxECiHAHcJaV6FZQWS","level":3,"time":"2026-02-08T12:45:43+00:00","remoteAddr":"78.51.70.7","user":"admin","app":"app_api","method":"POST","url":"/apps/app_api/apps/enable/flow/docker_aio","scriptName":"/index.php","message":"Error executing occ command. Return code: 1, stdout: , stderr: ","userAgent":"Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0","version":"32.0.4.1","data":{"app":"app_api"}}
PASTE HERE
"one-click-instance": true,
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"redis": {
"port": 6379
"overwritehost": "nextcloud.mydomain.com",
"overwriteprotocol": "https",
"localhost",
"dbtype": "pgsql",
"version": "32.0.4.1",
"overwrite.cli.url": "https:\/\/nextcloud.mydomain.com\/",
"updatechecker": false,
"loglevel": 2,
"log_type": "file",
"log_rotate_size": 10485760,
"log.condition": {
"apps": [
"admin_audit"
"preview_max_x": 2048,
"preview_max_y": 2048,
"jpeg_quality": 60,
"enabledPreviewProviders": {
"1": "OC\\Preview\\Image",
"2": "OC\\Preview\\MarkDown",
"3": "OC\\Preview\\MP3",
"4": "OC\\Preview\\TXT",
"6": "OC\\Preview\\Movie",
"7": "OC\\Preview\\Krita",
"enable_previews": true,
"upgrade.disable-web": true,
"mail_smtpmode": "smtp",
"activity_expire_days": 30,
"share_folder": "\/Shared",
"htaccess.RewriteBase": "\/",
"dbpersistent": false,
"DOMAIN": "nextcloud.mydomain.com"
- activity: 5.0.0-dev.0
- admin_audit: 1.22.0
- app_api: 32.0.0
- calendar: 6.1.6
- circles: 32.0.0
- comments: 1.22.0
- contacts: 8.3.1
- contactsinteraction: 1.13.1
- dashboard: 7.12.0
- dav: 1.34.2
- deck: 1.16.3
- federation: 1.22.0
- files: 2.4.0
- files_reminders: 1.5.0
- files_sharing: 1.24.1
- files_trashbin: 1.22.0
- files_versions: 1.25.0
- firstrunwizard: 5.0.0-dev.0
- logreader: 5.0.0-dev.0
- nextcloud-aio: 0.8.0
- notes: 4.13.0
- notifications: 5.0.0-dev.0
- notify_push: 1.3.0
- oauth2: 1.20.0
- photos: 5.0.0-dev.1
- privacy: 4.0.0-dev.0
- profile: 1.1.0
- provisioning_api: 1.22.0
- richdocuments: 9.0.2
- serverinfo: 4.0.0-dev.0
- settings: 1.15.1
- sharebymail: 1.22.0
- spreed: 22.0.8
- support: 4.0.0-dev.0
- survey_client: 4.0.0-dev.0
- systemtags: 1.22.0
- tasks: 0.17.1
- text: 6.0.1
- theming: 2.7.0
- twofactor_totp: 14.0.0
- updatenotification: 1.22.0
- user_status: 1.12.0
- viewer: 5.0.0-dev.0
- weather_status: 1.12.0
- webhook_listeners: 1.3.0
- whiteboard: 1.5.5
- workflowengine: 2.14.0
- encryption: 2.20.0
- files_external: 1.24.0
- user_ldap: 1.23.0
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
