Flow activation: rules were requested for operation Block access to a file
HI
The user is trying to upload files from IPv6 Machine
and we are getting file upload issues from API on nextcloud server
Getting this error
“Flow activation: rules were requested for operation Block access to a file”
and
“No flow configurations is going to run Block access to a file”
can anyone update me
Did you ever figure this out? Seeing the same thing.
This seems to be related. The solution was to disable / remove the File Access Control app.
Worked for me as well, at least for the logs.
