Nextcloud 32 RC1 is now available on our download server! ![]()
We’d love your help putting this release through its paces.
If you run into any issues, please report them in the appropriate GitHub repository. ![]()
This is the first RC and some others are planned on next Thursdays. Stay tuned!
Downloads
Changelog
server
- Fix(dav): Mark removal of dav object properties as expensive (server#50391)
- Feat(occ): add default help text with docs link to all commands (server#54180)
- Fix(dav): clean up user’s addressbook shares on deletion (server#54424)
- Fix: propfind query monitor breaking removeListener and removeAllList… (server#54507)
- Fix(lexicon): send single notice/warning when using unknown config key (server#54739)
- Fix(dav): ensure moving or copying a file is possible (server#54801)
- Test: add cypress tests for the systemtags files view (server#54820)
- Fix(Filesystem): use FilenameValidator for `Filesystem::isFileBlacklisted` (server#54821)
- Fix(comments): use showFile route to reference files with a matching … (server#54826)
- Fix(theming): Remove header-icon-mask in dark-mode high-contrast as well (server#54832)
- Fix(settings): Settings presets are called “Quick presets” (server#54833)
- Fix dashboard icons (server#54836)
- Fix(l10n): use `productName` instead of hardcoded ‘Nextcloud’ where possible (server#54838)
- Perf(users): Create lazy users in IUserManager::getSeenUsers (server#54839)
- Fix(files_sharing): add some gap between text and sharing status icon (server#54841)
- Fix: the account files filter should also work in trashbin (server#54847)
- Welcome stable32 (server#54862)
- Fix(security): Update Expires time (server#54868)
3rdparty
bruteforcesettings
files_pdfviewer
- Update @nextcloud/eslint-config to 9.X (files_pdfviewer#1237)
- Chore: Update GitHub workflows from templates (files_pdfviewer#1248)
firstrunwizard
- Chore: 29 is EOL remove it from dependabot (firstrunwizard#1655)
- Ci: update workflows from organization (firstrunwizard#1659)
- Perf: only add background jobs and app hint notifications on login (firstrunwizard#1660)
- Feat: add share by bluesky and linkedin (firstrunwizard#1663)
- Feat: add hub release information for Hub 25 Autumn (firstrunwizard#1665)
- Fix: gracefully handle disabled autoplay policies (firstrunwizard#1666)
photos
- Fix(AutomaticPlaceMapperJob): Do not fail when there are no users (photos#3148)
- Missing migration attributes (photos#3149)
