First feedback to howto article
For me it is not really clear what you struggled with and what you finally solved. Is it just having the whole DNS setup with full ipv4/ipv6 support? And then let the pi-hole dns run in your local network?
What is caddy? Why do I need it?
For a howto, there should be a bit more background.
Or if you have a regular post, you have a question, and then a specific solution.
As for Your questions:
Caddy is a web server that automatically obtains and renews TLS certificates for all your sites
https://caddyserver.com/docs/automatic-https
I need caddy because, it is recommended to
Set up a local DNS-server that allows to automatically connect to the server in the home network via the same domain by using the internal ip-address of the server (see this doc)
https://github.com/nextcloud/all-in-one/discussions/1335
and because
The normal way is the following:
Set up your domain correctly to point to your home network
Set up a reverse proxy by following the reverse proxy documentation but only open port 80 (which is needed for the ACME challenge to work - however no real traffic will use this port).
Set up a local DNS-server like a pi-hole and configure it to be your local DNS-server for the whole network. Then in the Pi-hole interface, add a custom DNS-record for your domain and overwrite the A-record (and possibly the AAAA-record, too) to point to the private ip-address of your reverse proxy …
Enter the ip-address of your local dns-server in the daemon.json file for docker so that you are sure that all docker containers use the correct local dns-server.
Now, entering the domain in the AIO-interface should work as expected and should allow you to continue with the setup
https://github.com/nextcloud/all-in-one/blob/main/local-instance.md
What I struggled with, was the number of variants enumerated in the section last mentioned.
What I find comparatively helpful is
  • to point out a single solution to comply to the recommendation
  • that is also simple:
    • uncomment some lines in the official compose.yaml to install and configure a reverse proxy with automatic HTTPS
    • use pi-hole as a community container
    • focus on preconditions
      • reachabilty
      • solve the port conflict from DNSListenerStub
Would that be enough background for a HowTo or a Community Anleitung?
Improved version #3
#Newbie setup of AIO for local network access
For AIO performance it is, among others, recommended to
Set up a local DNS-server that allows to automatically connect to the server in the home network via the same domain by using the internal ip-address of the server (see this doc) https://github.com/nextcloud/all-in-one/discussions/1335
And because
I here propose a simple solution to comply to that recommendation:
  • focus on preconditions:
  • Use the official compose.yaml slightly modified to configure an AIO instance behind a reverse proxy with automatic HTTPS
Preconditions
Setup
Differing from the AIO repo readme:
  • The docker compose file - see below - is a copy of the one in the AIO Repo with some lines for caddy uncommented.
  • The other is, that in order to fire up aio setup, You employ this command:
sudo docker compose up -d # in the file's directory
  • Once the administration interface is up and Your domain is set, add pi-hole as a community container from the setup page and proceed as described in in the AIO repo section for pi-hole.
As an aside: I recommend You set Your backup location to BorgBase.org, while You are it.
Helpers
  • DNS Lookup - Check All DNS Records for Any Domain
  • Port Checker - Check Open Ports Online
  • Advice from the aio repo how to reset Your instance:
    #!/bin/bash
    docker stop nextcloud-aio-mastercontainer
    docker stop nextcloud-aio-domaincheck
    docker ps --format {{.Names}}
    for cntr in $(docker ps --format {{.Names}})
    do
    	docker stop $cntr
    done
    docker ps --filter "status=exited"
    docker container prune
    docker network rm nextcloud-aio
    docker volume ls --filter "dangling=true"
    docker volume prune --filter all=1
    rm -rf /media/mf/kingston/*
    docker volume ls --format {{.Name}}
    docker image prune -a
compose.yaml
services:
    image: ghcr.io/nextcloud-releases/all-in-one:latest
    init: true
    restart: always
    volumes:
    network_mode: bridge # add to the same network as docker run would do
    ports:
      - 8080:8080
      - 8443:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # AIO_DISABLE_BACKUP_SECTION: false # Setting this to true allows to hide the backup section in the AIO interface. See https://github.com/nextcloud/all-in-one#how-to-disable-the-backup-section
       APACHE_PORT: 11000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
       APACHE_IP_BINDING: 127.0.0.1 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else) that is running on the same host. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
#      APACHE_ADDITIONAL_NETWORK: frontend_net # (Optional) Connect the apache container to an additional docker network. Needed when behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else) running in a different docker network on same server. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # BORG_RETENTION_POLICY: --keep-within=7d --keep-weekly=4 --keep-monthly=6 # Allows to adjust borgs retention policy. See https://github.com/nextcloud/all-in-one#how-to-adjust-borgs-retention-policy
      # COLLABORA_SECCOMP_DISABLED: false # Setting this to true allows to disable Collabora's Seccomp feature. See https://github.com/nextcloud/all-in-one#how-to-disable-collaboras-seccomp-feature
      # FULLTEXTSEARCH_JAVA_OPTIONS: "-Xms1024M -Xmx1024M" # Allows to adjust the fulltextsearch java options. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-fulltextsearch-java-options
      # NEXTCLOUD_DATADIR: /mnt/ncdata # Allows to set the host directory for Nextcloud's datadir. ⚠️⚠️⚠️ Warning: do not set or adjust this value after the initial Nextcloud installation is done! See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
      # NEXTCLOUD_MOUNT: /mnt/ # Allows the Nextcloud container to access the chosen directory on the host. See https://github.com/nextcloud/all-in-one#how-to-allow-the-nextcloud-container-to-access-directories-on-the-host
      # NEXTCLOUD_UPLOAD_LIMIT: 16G # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-upload-limit-for-nextcloud
      # NEXTCLOUD_MAX_TIME: 3600 # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-max-execution-time-for-nextcloud
      # NEXTCLOUD_MEMORY_LIMIT: 512M # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-php-memory-limit-for-nextcloud
      # NEXTCLOUD_TRUSTED_CACERTS_DIR: /path/to/my/cacerts # CA certificates in this directory will be trusted by the OS of the nextcloud container (Useful e.g. for LDAPS) See https://github.com/nextcloud/all-in-one#how-to-trust-user-defined-certification-authorities-ca
      # NEXTCLOUD_STARTUP_APPS: deck twofactor_totp tasks calendar contacts notes # Allows to modify the Nextcloud apps that are installed on starting AIO the first time. See https://github.com/nextcloud/all-in-one#how-to-change-the-nextcloud-apps-that-are-installed-on-the-first-startup
      # NEXTCLOUD_ADDITIONAL_APKS: imagemagick # This allows to add additional packages to the Nextcloud container permanently. Default is imagemagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-os-packages-permanently-to-the-nextcloud-container
      # NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS: imagick # This allows to add additional php extensions to the Nextcloud container permanently. Default is imagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-php-extensions-permanently-to-the-nextcloud-container
      # NEXTCLOUD_ENABLE_DRI_DEVICE: true # This allows to enable the /dev/dri device for containers that profit from it. ⚠️⚠️⚠️ Warning: this only works if the '/dev/dri' device is present on the host! If it should not exist on your host, don't set this to true as otherwise the Nextcloud container will fail to start! See https://github.com/nextcloud/all-in-one#how-to-enable-hardware-acceleration-for-nextcloud
      # NEXTCLOUD_ENABLE_NVIDIA_GPU: true # This allows to enable the NVIDIA runtime and GPU access for containers that profit from it. ⚠️⚠️⚠️ Warning: this only works if an NVIDIA gpu is installed on the server. See https://github.com/nextcloud/all-in-one#how-to-enable-hardware-acceleration-for-nextcloud.
      # NEXTCLOUD_KEEP_DISABLED_APPS: false # Setting this to true will keep Nextcloud apps that are disabled in the AIO interface and not uninstall them if they should be installed. See https://github.com/nextcloud/all-in-one#how-to-keep-disabled-apps
       SKIP_DOMAIN_VALIDATION: false # This should only be set to true if things are correctly configured. See https://github.com/nextcloud/all-in-one?tab=readme-ov-file#how-to-skip-the-domain-validation
      # TALK_PORT: 3478 # This allows to adjust the port that the talk container is using which is exposed on the host. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-talk-port
      # WATCHTOWER_DOCKER_SOCKET_PATH: /var/run/docker.sock # Needs to be specified if the docker socket on the host is not located in the default '/var/run/docker.sock'. Otherwise mastercontainer updates will fail. For macos it needs to be '/var/run/docker.sock'
    # security_opt: ["label:disable"] # Is needed when using SELinux
#   # Optional: Caddy reverse proxy. See https://github.com/nextcloud/all-in-one/discussions/575
#   # Alternatively, use Tailscale if you don't have a domain yet. See https://github.com/nextcloud/all-in-one/discussions/5439
#   # Hint: You need to uncomment APACHE_PORT: 11000 above, adjust cloud.example.com to your domain and uncomment the necessary docker volumes at the bottom of this file in order to make it work
#   # You can find further examples here: https://github.com/nextcloud/all-in-one/discussions/588
  caddy:
    image: caddy:alpine
    restart: always
    container_name: caddy
    volumes:
      - caddy_certs:/certs
      - caddy_config:/config
      - caddy_data:/data
      - caddy_sites:/srv
    network_mode: "host"
    configs:
      - source: Caddyfile
        target: /etc/caddy/Caddyfile
configs:
  Caddyfile:
    content: |
      # Adjust cloud.example.com to your domain below
      https://agdaz.online:443 {
        reverse_proxy localhost:11000
volumes: # If you want to store the data on a different drive, see https://github.com/nextcloud/all-in-one#how-to-store-the-filesinstallation-on-a-separate-drive
  caddy_certs:
  caddy_config:
  caddy_data:
  caddy_sites:
it’s getting a bit messy here, I think… so what about taking your edited version, edit your starting posting and just overwrite the first posting with the newest one?
for better overview you could give your versions a counter in the beginning
like
“improved version #3” or such.
diese Version ist gut. die mit improved version anfängt
Initial post is overwritten now with a version containing answers to @tflidd 's questions, which I also found helpful.
Ok, it becomes clearer now.
Sorry, that I didn’t know caddy was a reverse proxy. From the links and the context it is clearer now, I’d just add that:
after reverse proxy (caddy)
and
(DNS server).
:+1:
I think, then we just move our discussion stuff to a separate thread, that here we keep some space for user’s feedback.
I split the first part of discussions from the original howto to create some space for feedback from users.
