The first beta of Nextcloud 32 is now available on our download server! ![]()
If you notice anything out of order, please report back on the appropriate github repository! ![]()
We will follow up with frequent betas over the next weeks.
Downloads
Changelog
server
- Make it possible to run occ as root (server#33545)
- Donât believe sftp when it tells us the mtime is less than we know it is (server#40105)
- [Proposal] Inform user about master key generation on encryption enabling (server#40468)
- Fix(dashboard): performance and refactoring (server#41065)
- Refactor(App): Remove registerRoutes method (server#42678)
- Fix(user_ldap): Do not map groups we do not know if they match filter (server#45364)
- Fix(TaskProcessing): Catch JSON encode errors in Manager#setTaskResult (server#46780)
- Fix: remove caching in fetchListOfGroups (server#47513)
- Refactor(style): Remove repeated semicolon (server#47648)
- Fix: Move login via email logic to local backend (server#47686)
- Fix: `user:settings` command when user is not available (server#47889)
- Ci: Install PHPUnit 10 (server#48210)
- New occ commands to manage system-tags for files (server#48277)
- Feat(encryption): Migrate from hooks to events (server#48560)
- Fix: Filter for folders in cleanup old preview job (server#48581)
- Fix(settings): Add some context to the PHP memory limit error (server#48672)
- Fix(updater): make clean-up job more robust / easier to debug (server#48674)
- Perf: Log requests using high amount of memory as warning (server#48738)
- Feat: support migrating an instance to sharding (server#48795)
- Add the option to provide a groupname and only see itsâ members in occ group:list (server#49016)
- Fix(db): Stop writing unused `dbport` to config at install time (server#49104)
- Fix(SetupChecks): Pass webfinger if the handler returns 400 too (server#49440)
- Fix: adjust url for task links (server#49639)
- Fix(config): drop value details (server#49645)
- Clarify app manager method names (server#49648)
- Update & Expand Meta Tags (server#49872)
- Fix: when already upgrading, donât instruct to run `occ upgrade` (server#49955)
- Fix: Change UserAgent to *cloud (server#50053)
- Fix OCM implementation has wrong parameter names (server#50069)
- Fix(core): Fix undefined âapplicationâ array key error (server#50081)
- Feat(cardav): support result truncation for addressbook federation (server#50092)
- Fix(AppFramework): Log malformed protocol values and unify fallback behavior (server#50099)
- Fix(unified-search): load more than 5 items in folder filter (server#50129)
- Feat: add example contact on first login (server#50156)
- Feat(UserMountCache): Emit events for added, removed and updated mounts (server#50157)
- Fix(oauth2): adjust db schemas when migrating from owncloud (server#50193)
- Add integration tests for moving a file from and to a shared folder (server#50221)
- Fix(ratelimit): Allow to bypass rate-limit from bruteforce allowlist (server#50234)
- Perf(files_reminders): Reduce db queries on propfind (server#50244)
- Implement Directory Check (server#50258)
- Chore : Comprehensive e2e testing for public sharing (server#50260)
- Fix(files_sharing): Respect permissions passed when creating link shares (server#50270)
- Fix: Metadata field search (server#50273)
- Fix(settings): Fix setup check when mail_smptmode is set to ânullâ (server#50281)
- Refactor: Sharing sidebar UI redesign (server#50282)
- Chore: update icewind/smb to 3.7.0 (server#50284)
- Fix opening federated shares (server#50292)
- Fix(theming): Harden admin theming settings (server#50293)
- Fix: detect deleted items as updated for smb storage (server#50298)
- Fix(files_versions): Update `unencrypted_size` during rollback (server#50299)
- Chore(3rdparty): Bump symfony/process from 6.4.12 to 6.4.15 (server#50315)
- Chore(tests): Make linter happy in cypress tests (server#50318)
- Fix(theming): remove node-vibrant dependency and usage (was moved to backend) (server#50320)
- Fix: donât use cached root info from shared cache if the watcher has detected an update (server#50324)
Master is now 32 (server#50330)- Fix(taskprocessing): More caching (server#50331)
- Feat: Support X-NC-Skip-Trashbin header (server#50353)
- Fix(translations): Fix profile and webhook_listeners (server#50355)
- Fix: remove return type (server#50362)
- Fix(files): support submenu in batch actions header too (server#50364)
- Chore: add profile translations reuse license (server#50365)
- Fix(systemtags): Use literal strings for i18n in showSuccess (server#50366)
- Fix: Properly read updater channel before returning version channel as a fallback (server#50368)
- Fix(dav): default calendar and address book not created on first login (server#50369)
- Revert âfix(Share20\Manager): Ensure node is still accessible when checking shareâ (server#50389)
- Ci(reuse): Fix translation reuse mapping (server#50394)
- Fix: Correctly return app id and app version for `core` styles and images (server#50398)
- Feat: Use redundant label for accesibility only (server#50399)
- Fix(LDAP): also log why the connection to main server failed (server#50405)
- Fix(settings): Clarify peculiarities of enabling encryption (server#50424)
- Fix outdated OpenAPI specs (server#50425)
- Fix(occ): hide sensitive data while config:app:set (server#50426)
- Files: harden thumbnail endpoint (server#50430)
- Fix: Harden files scanner for invalid null access (server#50436)
- Docs(dispatcher): Correct described return values (server#50444)
- Fix(unifiedsearch): Simplify and correct thumbnail styles (server#50446)
- Fix: Ensure `label` is always a string (server#50447)
- Chore: update php intl stub and fix type issues (server#50452)
- Fix(log): Fix log level handling (server#50455)
- Hide âCreate templates folderâ option if templates are disabled (server#50464)
- Fix: Check that user actually can validate password for js (server#50465)
- Fix: make early check if users filesystem have a mountpoint at //files (server#50470)
- Improve error detail when saving an incorrect LDAP config (server#50475)
- Fix(CalDav): Spelling (server#50490)
- Fix(performance): use low resolution for blurhash (server#50494)
- Fix(ci): cypress container name (server#50496)
- Donât rethrow a type error (server#50498)
- Fix: Increase background and primary color debounce time (server#50501)
- Fix(theming): Do not throw in background color migration (server#50503)
- Feat(S3): add SSE-C support in S3 External Storage (server#50514)
- Fix: Show recipient email addresses in share owner notification email (server#50515)
- Fix: Exclude non accepted shares when computing access list (server#50519)
- Fix(files_sharing): file request form validity check reset (server#50524)
- Fix(ConvertType): Read dbtype in createConnectionParams and remove safeguard (server#50530)
- Fix: Only hide template folder creation if default was changed to empty (server#50540)
- Fix(files_sharing): skip expiration notify for invalid share record (server#50542)
- Fix: unified search provider id (server#50550)
- Perf(files): Check node type property instead of instance (server#50553)
- Add LDAP test settings command (server#50567)
- Fix(files): Fix folder preview for favorites widget (server#50576)
- Enh/apply rector set to apps (server#50577)
- Fix(files): Correctly scroll selected file into view (server#50582)
- Fix(unified-search): filteredProviders now inherits all provider props (server#50592)
- Fix: template field title (server#50602)
- Chore(files): Adjust wording (server#50635)
- Fix(TaskProcessing\Manager): Always use distributed cache and use PHP serialize (server#50640)
- Fix(sharing): better handle file share attributes (server#50642)
- Fix(files): properly update store on files conversions success (server#50645)
- Feat(login-flow-v2): Restrict allowed apps by user agent check (server#50650)
- Enh: Fix display default expire date, add tests & tiny refactors (server#50655)
- Fix(theming): high contrast themes scrollbar (server#50657)
- Fix: make sure we process mime extensions as string (server#50660)
- Chore(deps): Bump stecman/symfony-console-completion (server#50661)
- Enh: improve occ file:transfer-ownership logging (server#50663)
- Feat(theming): allow to disable standalone windows (server#50666)
- Fix(files): Do not download files with openfile query flag (server#50669)
- Fix(AccountProperty): better validation of twitter and fediverse handles (server#50678)
- Fix(files): only send config update requests if user is logged in (server#50680)
- Fix(dav): Migrate from hooks to user events (server#50689)
- Fix(emailTemplate): use instance Name instead of Url in subject (server#50692)
- Feat(admin_audit): write admin audit log for AnyLoginFailedEvent (server#50697)
- Feat(object_store): Add support for session token (STS) in AWS credentials (server#50702)
- Build(deps): Bump icewind/searchdav from 3.1.0 to 3.2.0 (server#50708)
- Fix(files_reminders): Only allow updating reminders if the file is accessible (server#50711)
- Fix(setupcheck): Update setup check for PHP version to be more accurate (server#50735)
- Feat(sharing): Allow to set default view mode for public shares (server#50739)
- Fix(transifex): Adjust check for translation of apps (server#50753)
- Update doc comment for prefixTableName (server#50764)
- Perf(cron): Delay (re)checking timed jobs (server#50768)
- Fix(SharedStorage): Check if storage ID is set on cache (server#50769)
- Test(Mailer): Align tests for mailer with stable30 (server#50779)
- Perf(files): faster query to fetch incomplete directories (server#50781)
- Fix(workflowengine): require a web component as operation plugin (server#50783)
- Fix: Fix regression in calendar invitation sending (server#50784)
- Chore(filecache): remove index fs_id_storage_size (server#50791)
- Fix: Only keep allowed characters in appid, and flag the method as escaping (server#50794)
- Fix(login): only show error state on login box if user interacted (server#50798)
- Fix: Fix psalm taint errors (server#50800)
- Fix(files): properly forward open params from short urls (server#50807)
- Fix(repair): PHP8.3 deprecation warning (server#50809)
- Fix(systemtags): do not hide if no tags (server#50814)
- Fix(transferownership): Allow searching new owner by email (server#50816)
- Fix(files_sharing): Fix public share expiration being set when toggle is not enabled (server#50820)
- Feat: Support deleting metadata from WebDAV (server#50852)
- Fix(oauth2): retain support for legacy ownCloud clients (server#50858)
- Fix(activity): Fix activity parameter types (server#50860)
- Fix: Fix psalm taint false-positives by small refactorings (server#50864)
- Fix(files_sharing): block downloading if needed (server#50873)
- Fix: Initialize lastConnectionCheck after first connection (server#50874)
- Fix(dav): Handle end of stream in `File::put` (server#50881)
- Refactor: Update `@nextcloud/vue` to 8.23.1 and update imports (server#50886)
- Fix(cron): Keep job class limitation when searching for the next job (server#50896)
- Fix(files_versions): Do not expire versions newer than min age (server#50903)
- Fix(files): do not show extension warning for folders renaming (server#50904)
- Fix(files_sharing): rate limit share creation 20 times per 10 minutes (server#50905)
- Chore: Adjust `OCP\Server::get` annotation to work with phpstan (server#50908)
- Fix(files_external): request strict password auth on credentials enter action (server#50910)
- Enh(SystemTag): Make MapperEvent webhook compatible (server#50916)
- Fix(files_sharing): Map sharee information for `shared-by-you` view (server#50918)
- Fix(files): Ensure the filter instance is mounted (server#50919)
- Revert âfix(files): updateAll methodâ (server#50920)
- Fix(files_sharing): Also list deleted team shares (server#50922)
- Feat(setupcheck): check logging level for validity (server#50927)
- Feat: add system address book settings in ui (server#50933)
- Fix(cron): Ignore time sensitivity when a class was explicitely scheduled (server#50942)
- Fix(files): handle failed node properly (server#50943)
- Fix(l10n): Fix triple dot in translation (server#50946)
- Ci(autochecks): Run some autochecks also on non-PHP files (server#50949)
- Fix: wipe local storages on log out (server#50956)
- Fix: rename âedit locallyâ to âopen locallyâ (server#50957)
- Fix: NotFoundException for anonymous users (server#50958)
- Feat(files): allow to ignore warning to change file type (server#50979)
- Fix: validate account properties as a repair step (server#50985)
- Spelling standardization (server#50987)
- Fix: Use case insensitive check when validating login name (server#50989)
- Refactor: move version rollback hook to event (server#50990)
- Chore: Automated request for reviews of pull request (server#50991)
- Fix(admin_audit): Fix incorrect truncation of files path in admin audit log (server#50992)
- Fix: Replace OC_App calls by IAppManager (server#50999)
- Fix(FederatedShareProvider): Delete external shares when groups are deleted or users removed from a group (server#51000)
- Fix: rework UploadFolder implementation (server#51010)
- Fix(files_external): Move definition parameter to the correct place (server#51019)
- Fix: Transfer ownership with S3 as primary (server#51020)
- Fix: Deprecate OC_Template, add proper template manager instead (server#51029)
- Fix(singularandpluralfiles):implemented ternary operator to handle si⌠(server#51031)
- Fix(l10n): Improve english source strings (server#51049)
- Fix: Report duplicated extra files in integrity check (server#51050)
- Feat: Close sessions created for login flow v2 (server#51051)
- Fix SQL query so that it is ansi safe fixing #51067 (server#51069)
- Fix(translation): Fix string concatenation in LDAP endpoint (server#51071)
- Feat: log query for dbal exceptions (server#51073)
- Files: fix exception when share-attributes is undefined (server#51077)
- Fix(files_reminders): Do not attempt to send reminders after a user has left a share (server#51079)
- Fix(CalDAV): add calendar enable (server#51081)
- Feat(dav)!: add webhook compatibility for calendar object events (server#51082)
- Feat(PWA): add `display_override` to set the display-mode to `minimal-ui` on supported browsers (server#51092)
- Chore: auto sync min desktop version with last supported version (server#51094)
- Fix(login): Ephemeral sessions (server#51095)
- Fix(LDAP): use ldap_set_option over putenv to disable cert check (server#51096)
- Fix disabled user list for SAML group subadmin (server#51108)
- Feat(OCM-invites): Implementation of invitation flow for OCM 1.1.0 (server#51113)
- Feat(AppFramework): extend range check to optional parameters (server#51116)
- Fix(cypress): wait for toast to appear (server#51126)
- Fix: Do not build encrypted password if there is none (server#51130)
- Fix(imip): dont compare events for the reply message (server#51131)
- Ci: fix request-reviews workflow (server#51135)
- Feat: command to list and delete calendar subscriptions (server#51136)
- Remove space (server#51142)
- Fix(dav): Create SAB at installation (server#51144)
- Fix(files_trashbin): disable bulk download for trashbin (server#51146)
- Chore: Use codeowners instead of workflow to assign reviewers (server#51147)
- Fix(files): also show file list headers on empty views (server#51148)
- Fix(files_sharing): ignore duplicated navigation when replacing current route (server#51151)
- Fix(files_sharing): ensure downloaded file has the correct filename (server#51152)
- Include âbackground_colorâ in list of supported keys (server#51181)
- [master] Fix A+ rating when checking with Nextcloud Security Scan. (server#51184)
- Feat(db): add truncateTable method (server#51190)
- Refactor(TempManager): Simplify and unify implementations and remove legacy behavior (server#51194)
- Feat: Allow AVIF content type in PhotoCache (server#51195)
- Build(integration): Disable password_policy app (server#51196)
- Test(e2e): adjust trashbin tests to be less flaky (server#51211)
- Fix: remote account activity translation (server#51216)
- Feat: Add bases and gidNumber attribute to ldap:test-user-settings output (server#51218)
- Feat(appconfig): removing pre-migration check (server#51221)
- Fix(lookup_server_connector): correctly handle account properties (server#51229)
- Fix(Comment): replace richEditor mixin with NcRichText (server#51239)
- Chore(deps): update `@nextcloud/upload` to 1.9.0 (server#51243)
- Chore(CODEOWNERS): do not spam backenders with frontend PRs related to `dist/` (server#51246)
- Fix: pass hide download attribute while creating the share to fix github issue 50788 (server#51250)
- Fix(dav): Handle long absence status earlier (server#51256)
- Fix(dav): Use IUser::getDisplayName directly (server#51258)
- Fix(files): Donât do session related work in the constructor of the View (server#51259)
- Fix(theming): use plain string in `t` method (l10n) (server#51266)
- Chore(deps): switch davclient library to nextcloud-deps fork (server#51267)
- Fix(login): Properly target public page with attribute (server#51280)
- Fix(l10n): Remove leading space from translation string (server#51287)
- Fix(systemtags): unify restrict_creation_to_admin handling (server#51288)
- Fix: optimize FileUtils::getFilesByUser (server#51296)
- Test: Remove `.only()` calls (server#51302)
- Test(cypress): rename select all clear (server#51309)
- Fix(encryption): Listen for user login and logout to set encryption key (server#51310)
- Fix(external_storage): fix settings save (server#51320)
- Fix(files): Make sure file pointer exists (server#51333)
- Fix(settings): Fix infinitely loading account management page with pagination of groups (server#51336)
- Fix(federatedfilesharing): warn when enabling lookup server data upload (server#51352)
- Refactor: cleanup rollback hook usage (server#51355)
- Fix(base.php): Correct order for booting \OC\Server (server#51361)
- Fix(files_external): Stop building path twice when checking if file exists on case insensitive SMB storage (server#51364)
- Fix(dav): Fix share token pattern for base uri extraction (server#51365)
- Fix(lookup-server): disable when not using global scale (server#51378)
- Fix(AppDiscover): Strip double-quotes from folder name (server#51379)
- Fix(cardav): only show users from enabled addressBooks in contacts menu (server#51380)
- Fix(lookup-server): Only flag new users for lookup update / delete (server#51384)
- Fix: Remove multiple require_once calls for template functions (server#51385)
- Fix: skip caching lastSeenQuotaUsage for remote shares (server#51389)
- Allow to delete files without trashbin + add unit tests + some refactoring (server#51394)
- Add command to list shares (server#51399)
- Test: speed up hotkey tests by 2.4s (server#51400)
- Chore(dev-deps): Drop dependency on jsdoc (server#51403)
- Fix(mimetypes): drop `tar.gz` and `tar.bz2` and adjust `tgz` (server#51405)
- Fix(unified-search): do not overlap search bar with button (server#51418)
- Feat(bulk-upload): change the default to disabled as there are still some bugs present (server#51431)
- Fix(GenerateBlurhashMetadata): Suppress imagescale errors (server#51433)
- Fix(mime-types): adjust compiled mime types and sign (server#51434)
- Perf(db): Extend index on cards_properties to cover name and value (server#51438)
- Fix(db): Create replacement index where original index is missing (server#51439)
- Fix(CalDav): alter invitation attachment filename and type (server#51441)
- Fix(RichObjectStrings): Make exception messages for invalid parameters more useful for debugging (server#51442)
- [master] revert(deps): jquery-ui to 1.13.3 (server#51446)
- Fix: resolve typo in authMethod enum cases (server#51449)
- Fix(dav): do not require CSRF for safe and indempotent HTTP methods (server#51457)
- Fix public download activity (server#51458)
- Feat(core): migrate setup to vue (server#51464)
- Test(core): add setup cypress tests (server#51468)
- Fix(files_sharing): ensure share status action works also in grid view (server#51469)
- Fix(files): Ensure actions never overflow filename (server#51471)
- Fix(profile): allow to unset phone number (server#51477)
- Chore: drop outdated deprecation comment from Mailer (server#51480)
- Fix(database): Cast users count to integer (server#51490)
- Fix(dav): allow uploading of files with long filenames (server#51491)
- Fix: add event status and participant status (server#51501)
- Fix(comments): Fix activity rich subject parameters (server#51512)
- Ci: Update 3rdparty actions (server#51520)
- Fix(webauthn): adjust for updated library and add tests (server#51521)
- Fix: adjust webpack nonce generation (server#51524)
- Fix(login): simplify code and use consistent layout (server#51540)
- Fix(auth): Allow 2FA challenges for Ephemeral sessions (server#51544)
- Fix(IMimeTypeDetector): use correct return type (server#51564)
- Refactor(IMimeTypeDetector): use consistent capitalization (server#51567)
- Feat(files): Add capability for clients to check WCF state (server#51568)
- Test(cypress): wait for button to be visible (server#51587)
- Chore(test): use consistent tabs for indention in behat tests (server#51591)
- Fix(dav): throw invalid argument when property type does not match (server#51592)
- Fix(occ): Suppress errors when checking config.php fileowner (server#51594)
- Fix(deps): lock mdast-util-gfm-autolink-literal library to exact version 2.0.0 (server#51598)
- Feat: Limit `ExpireTrash` job to 30 minutes (server#51600)
- Chore: update `@nextcloud/upload` to version 1.9.1 (server#51601)
- Fix: Use default share folder of the user on share accept (server#51602)
- Add command to list orphan objects (server#51603)
- Feat(files): add command to automatically rename filenames (server#51608)
- Fix(files_versions): only handle path updates when there is path (server#51609)
- Fix(IFilenameValidator): correctly handle case insensitivity (server#51611)
- Fix(ocm): `publicKey` can be disabled so capabilities do not match (server#51622)
- Feat: Add share expiration indicator (server#51630)
- Fix(user): Some strings not being translated (server#51644)
- Fix(systemtags): Dispatch events when bulk assigning system tags (server#51649)
- Chore(i18n): Improved grammar (server#51650)
- Cookie_domain config option for setting cookie on a wider domain (server#51657)
- Fix: Go back to soft typing for template function p (server#51663)
- Fix(provisioning_api): Pass on translated hint if password change fails (server#51668)
- Perf(sharing): Use oc_share.item_type IN instead of OR equals (server#51669)
- Feat(openapi): Generate merged spec for all apps (server#51674)
- Fix(setupchecks): Treat information messages as success (server#51675)
- Add OC_App::getAppVersions replacement in IAppManager (server#51676)
- Fix(dav): filter user files when updating tags (server#51682)
- Fix(files): Properly encode URLs when preparing ZIP download (server#51684)
- Fix(template): implement ITemplate directly (server#51686)
- Fix files_sorting cypress tests (server#51689)
- Fix(login): Improve CSRF error message for better user understanding (server#51697)
- Feat(files): hide âPersonal filesâ and âShared with othersâ views if user has no quota (server#51698)
- Feat(mimetypes): Added musicxml mimetypes (server#51703)
- Fix(files_versions): correctly show version author also for shared files (server#51705)
- Fix: filter out contacts with empty email addresses in sharee completion (server#51707)
- Enhancement: Better previews for HDR video (server#51712)
- Fix(dav): Allow underscores on custom links (server#51715)
- Fix: task type translations (server#51724)
- Feat: Support OC-Checksum in bulk upload (server#51729)
- Fix(files_reminders): Fix reminder actions being displayed on invalid nodes (server#51737)
- Fix(files_versions): Rely on server mime fallback icons (server#51744)
- Fix(settings): Handle email change restriction separately from display name change restriction (server#51745)
- Fix(dav): Give proper HTTP status code on MKCOL when quota exceeded (server#51750)
- Fix(theming): enforce theme also for login (server#51752)
- Fix(files_reminders): Lower disabled notifications app error to info (server#51760)
- Feat: show permissions in info:file output (server#51766)
- Fix(phpunit10): Migrate away from PHPUnit at() calls (server#51768)
- Fix(files): show hidden files and folders count in summary (server#51771)
- Store original path in object metadata (server#51779)
- Notification manager deterministic app call order (server#51800)
- Feat: Add new methods to list distinct mounts and retrieve all files in a mount (server#51810)
- Chore(i18n): Aligned spelling of âsub adminâ (server#51816)
- Feat: add command to get basic storage info (server#51818)
- Chore(legacy): Remove deprecated OC_Util::addScript and functions depending on it (server#51836)
- Chore(files_trashbin): Add user details in log from Trashbin (server#51837)
- Mark all methods of OC_Util as deprecated (server#51838)
- Fix: donât have sabre/dav send itâs own reponse if we already send the zip response (server#51845)
- Chore: remove scrutinizer (server#51848)
- Fix(encryption): init keys also when logged in using cookie auth (server#51852)
- Fix: display chinese character avatar (server#51855)
- Fix: Catch exceptions when expiring trashbin (server#51861)
- Fix(files): right click actions menu flicker (server#51863)
- Fix: use proper migration sorting when checking if a migration needs to be executed (server#51866)
- Fix: Use login name to check the password (server#51870)
- Chore: adjust CODEOWNERS (server#51874)
- Chore(deps): update `@nextcloud/vue` to `8.24.0` (server#51876)
- Chore: bump dependabot npm `open-pull-requests-limit` to 20 (server#51881)
- Fix(session): Only mark sessions of permanent tokens as app passwords (server#51905)
- Fix: improve handling of newFolder race condition handling (server#51920)
- Feat: add debug logging for adding/removing items from the user mounts cache (server#51921)
- Feat: Calendar Export (server#51924)
- Fix(systemtags): emit assign and unassign bulk tagging events (server#51927)
- Fix: ensure enabled (enforced) themes are always set on template layout (server#51933)
- Perf(files_sharing): do not emit second propfind for account filter (server#51937)
- Fix(cache): always require updates if mtime is null (server#51942)
- Fix(files_reminders): add missing import (server#51944)
- Chore: test that all apps are covered by psalm (server#51945)
- Perf(cloud_federation_api): only provide capabilities if needed (server#51946)
- Revert ârefactor: add migration for email settingâ (server#51982)
- Fix(federation): allows equal signs in federation id (server#51994)
- Fix(l10n): put placeholder like string into variable (server#52005)
- Fix: Proper order for checking path prefix for getting file by id from cache (server#52008)
- Fix: Handle missing share providers when promoting reshares (server#52013)
- Fix(preview): Fix constructor parameter name and default value (server#52014)
- Feat(ip): use larger IPv6 range by default (server#52015)
- Fix(dav): Really only run the chunk cleanup once (server#52019)
- Refactor(RichObjectStrings): Only log error if key or value is not string in validator (server#52035)
- Fix: more optimized caching for share target verification (server#52045)
- Introduce own method for calendar unsharing (server#52046)
- Fix: donât construct storage when checking if a sub-mount is applicable (server#52047)
- Fix(workflowengine): fix group not shown in Group membership check (server#52048)
- Fix(taskprocessing): use the event for AppAPI to get list of AI providers (server#52050)
- Feat(TaskProcessing): Add TextToSpeech provider (server#52051)
- Revert "refactor(RichObjectStrings): Only log error if key or value i⌠(server#52062)
- Fix(federation): Donât load the addressbook when resolving a cloud ID (server#52066)
- Test: Improve comments manager test output in case of failure (server#52070)
- Fix(files_sharing): file request pass empty string if password or expiration is disabled (server#52072)
- Fix: fix preloading files with no custom properties (server#52073)
- Fix(files_sharing): fix share creation error handling (server#52075)
- Fix(previews): avoid large file downloads for remote movie storage (server#52079)
- Ci: add check to ensure composer-bin is not accidentally committed (server#52080)
- Fix: reuse default navigation entry when updating navigation entries (server#52082)
- Fix(federation): Fix returning âno display nameâ after cache result (server#52085)
- Cleanup user backends related methods (server#52086)
- Chore(i18n): Use ânameâ instead of ânicknameâ (server#52094)
- Built in profiling capabilities with excimer (server#52099)
- Fix(TaskProcessing): for validation for taskprocessing EShapeType (server#52116)
- Fix(files_sharing): Apply default password setting in SharingDetailsTab (server#52121)
- Fix: donât return other mounts from share mount provider (server#52128)
- Fix: disable direct download for shares (server#52133)
- Revert âfeat(bulk-upload): change the default to disabled as there are still some bugs presentâ (server#52137)
- Chore(i18n): Aligned spelling of app name (server#52162)
- [master] ignore missing theming app (server#52166)
- Fix(ContextAgent): Do not translate the name ContextAgent (server#52168)
- Perf: Add index to select properties by name, path and user (server#52175)
- Fix: Remove support for app.php loading (server#52178)
- Ci: add Codecovâs test analytics and bundle analysis features (server#52179)
- Fix(files_sharing): bring back handling of `hide-download` on public shares (server#52180)
- Feat(dav): Enable chunked upload for public shares (server#52182)
- Chore: Output error content when test smb-kerberos-sso is failing (server#52212)
- Perf(carddav): donât query circle memberships (server#52215)
- Feat: add logging to preview generation (server#52221)
- Feat(security): add configurable IPv6 subnet for BFP and throttling (server#52223)
- Fix(usermanager): Donât throw when checking if a too long user id is an existing user (server#52224)
- Fix(CalDAV): do not ignore move command object target uri (server#52228)
- Fix(mail): use matching text color for primary elements (server#52240)
- Fix(caldav): Fix check for ROOM or RESOURCE condition (server#52241)
- Fix(S3): Use original folder size during copy (server#52242)
- Chore: drop scssphp dependency (server#52249)
- Fix(settings): allow to clear twitter and fediverse (server#52250)
- Fix(Log): revert swich to ?? operator (server#52252)
- Fix(LDAP): inlcude ldapExpertUsernameAttr in general attribute list (server#52257)
- Update AUTHORS (server#52267)
- Fix(files): make sure to always have proper plural forms (server#52269)
- Optionally allow logging parameters to query log (server#52276)
- Fix(CardDAV): do not ignore move command object target uri (server#52285)
- Refactor(files): share `mtime` for file entry components (server#52290)
- Chore: revert âfix(deps): lock mdast-util-gfm-autolink-literal libraryâ (server#52291)
- Ci(dependabot): remove stable29 and group composer directories (server#52293)
- Fix(files): prevent dragging preview when drag-drop (server#52296)
- Test: ignore git-ignored files from tests (server#52298)
- Refactor: Thumbnail Generator logging and tests (server#52299)
- Feat(files): allow showing file type (mime) column (server#52359)
- Fix(blurhash): Use preview API to generate the previews (server#52360)
- Fix(objectstorage): add retry attempts to S3 connection (server#52361)
- Fix(files_sharing): Improve expiration date input change handling (server#52364)
- Feat(profile): Add an API to get the profile field data (server#52366)
- Fix(files_versions): wait for version to be created before setting metadata (server#52369)
- Fix(files_versions): create version if previous does not exist (server#52373)
- Fix(updatenotification): Fix error handling when fetching applist for server update (server#52374)
- Fix(metadata): set background job on fresh setup (server#52375)
- Feat: add option to include external storage when transfering files (server#52378)
- Fix(Template): harden enabled-theme logic (server#52391)
- Fixbit): make `pack` compatible with 32bit PHP (server#52392)
- Chore(3rdparty): update `php-opencloud/openstack` to v3.12.0 for PHP8.4 (server#52396)
- Chore(deps): Bump laravel/serializable-closure from 1.3.5 to 2.0.4 (server#52400)
- Fixbit): use `PHP_INT_MAX` where needed (server#52402)
- Fix(federation): Allow federation file sharing when federation app is⌠(server#52404)
- Fix(caldav): use direct.edit route in event activities (server#52410)
- Fix(settings): only provide groups the subadmin has access to (server#52417)
- Fix(files_sharing): Show remote shares as external (server#52423)
- Fix(config): Censor more app configs in system report (server#52424)
- Refactor(dav): use first class callable syntax to boot the app (server#52427)
- Refactor(dav): refactor inline event listeners (server#52428)
- Fix(occ): Fix autocompletion of config:app:* commands (server#52429)
- Fix(navigation): Fix default app entry registered as closure (server#52434)
- Fix(files): middle click & ctrl new tab (server#52438)
- [master] fix(settings): Use axios directly for health check to preven URL sanitizing (server#52439)
- Fix: better error message when trying to scan a folder that is already being scanned (server#52441)
- Fix: donât check node access again for listing reminders in dav (server#52443)
- Chore: Update config.sample.php to document new ffprobe path option (server#52445)
- Fix(JSResourceLocator) fix incorrect parameter being used. (server#52479)
- Fix: check if config is enabled before creating a default contact (server#52494)
- Fix(files_sharing): Filter own shares that are reshares (server#52503)
- Feat(files_sharing): Add toggle to control display area for federated shares (server#52511)
- Feat: only get template fields once selected (server#52514)
- Fix(WFE): properly set inital status (server#52525)
- Fix(files_sharing): Prevent create/delete permissions on file shares (server#52526)
- Fix(files_sharing): bring back owner and ownerDisplayName initial state (server#52532)
- Fix: do not show account filter for public shares (server#52533)
- Perf(caldav): increase chunk size in RemoveOrphanEventsAndContacts repair step (server#52534)
- Fix(dav): check the owner displayName scope before giving attribute (server#52535)
- Feat(files_sharing): show Account menu on public pages (server#52537)
- Use PHP 8.4 lazy ghosts for Dependency injection (server#52538)
- Fix: Forward âextraâ argument when optimizing query (server#52542)
- Fix(share): assume download enabled on federated share (server#52543)
- Chore(IAccountManager): remove deprecated visibility constants (server#52544)
- Fix: Remove unneccesary etag check (server#52546)
- Fix(WeatherStatus): Check if result is an array (server#52551)
- Tests: Prepare more tests for PHPUnit 10 (server#52552)
- Chore(Constants): Sort by value (server#52558)
- Fix: Forward attributes to the sidebar (server#52565)
- Fix: Flaky samba kerberos tests (server#52572)
- Fix(notification): Notification in activity shows "Rich subject or a ⌠(server#52575)
- Ci: pin Codecov action versions by hash (server#52581)
- Fix(apps): Sort names separately from active/update state (server#52583)
- Fix(CI): fix CI in documentation repository (server#52584)
