every 20 minutes i get this error, but i have delete this file and i havent a versionsfile for it, how i can fix it?
Error PHP filesize(): stat failed for /home/xxx/xxx/files_versions/Arbeit/PGO/Pokemon_GO_Discord_Chat_fur_alle_Fraktionen.docx.v1469520899 at /var/www/nextcloud/lib/private/Files/Storage/Local.php#155
sudo -u “webuser” php occ files:scan --all
Scanning files for 12 users
Starting scan for user 1 out of 12 (Alv)
Home storage for user Alv not writable
Make sure you’re running the scan command only as the user the web server runs as
The file permissions or ownership are not correct. The user accessing your data directory needs to have write access. Depending on your server set up, this would be the web server, or perhaps the PHP user.
all users can upload files and work with nextcloud,
the web user have all rights on this folder so i cant say why the command “occ files:scan --all” say me i havent the correct ownerships
Is anyone else having this issue after updating to Nextcloud 18 from 17?
[PHP] Error: filesize(): stat failed for /var/www/nextcloud/data/aaron.lawson/files/Test/aaron_lawson_blue_shirt_profile_pic.psd.ocTransferId151376186.part at /var/www/nextcloud/lib/private/Files/Storage/Local.php#170
PUT /remote.php/webdav/Test/aaron_lawson_blue_shirt_profile_pic.psd
Does anyone know if this is something critical or have a solution to this? I wasn’t able to find recent threads with the issue…Any help is greatly apprecaited.
I have the same problem every time to upload a file:
` [PHP] Error: filesize(): stat failed for /var/www/html/data/xxxxx/files/xxxxxxxxxx.pdf.ocTransferId641220615.part at /var/www/html/lib/private/Files/Storage/Local.php#170`
PUT /remote.php/webdav/xxxxxxxxx.pdf
from xxx.xxxx.xxx.xxx by xxxxxxx at 2020-02-28T16:06:00+00:00
