Files not showing on web interface nextcloud
example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud 25.0.13
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.58
PHP version (eg, 7.4): Php 8.1
I have consistently faced an issue where files do not appear on the web interface despite using the command “sudo -u www-data php /var/www/html/nextcloud/occ files:scan --all -v.” Even after multiple attempts, the files remain invisible. Although the problem initially surfaced with Nextcloud version 25.0.12, it temporarily resolved after upgrading to 25.0.13, only to reoccur unexpectedly. Currently running version 25.0.13, I seek assistance in resolving this persistent issue. My Nextcloud server accommodates over 300 user accounts, and the storage is on a mounted NAS. Any guidance or solutions would be greatly appreciated. Thank you!
PASTE HERE
'instanceid' => ''Privacy',',
'passwordsalt' => ''Privacy',',
'secret' => ''Privacy',',
0 => '192.168.x.x',
1 => 'domain',
2 => '8.8.8.8',
3 => '192.168.x.x',
4 => 'x.x.x.x',
'datadirectory' => '/mnt/cloud',
'version' => '25.0.13.2',
'overwrite.cli.url' => 'https://domain',
'dbname' => ''Privacy',',
'dbhost' => 'localhost',
'dbuser' => 'Privacy',
'dbpassword' => 'Privacy',
'theme' => '',
'logtimezone' => 'Asia/Manila',
'loglevel' => 2,
'default_phone_region' => 'PH',
'enable_previews' => false,
'mail_from_address' => 'xxx',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'xxx',
'mail_smtpsecure' => 'ssl',
'mail_smtpport' => '465',
'mail_smtphost' => 'smtp.gmail.com',
'mail_smtpauth' => 1,
'mail_smtpname' => 'xxx',
'mail_smtppassword' => 'xxxx',
'allow_locate_remote_servers' => true,
'integrity.check.disabled' => true,
'trashbin_retention_obligation' => 'disabled',
'redis' =>
'host' => 'localhost',
'port' => 0,
'twofactor_enforced' => 'true',
0 => 'xxxx'
'trusted_proxies' =>
0 => 'xxxx',
'forwarded_for_headers' =>
0 => 'HTTP_X_FORWARDED_FOR',
1 => 'HTTP_X_REAL_IP',
[Mon Jan 15 15:39:17.976660 2024] [php:notice] [pid 410394] [client 192.168.26.1:53050] richdocumentscode (proxy.php) error exit, PID: 410394, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:39:19.236875 2024] [php:notice] [pid 410389] [client 192.168.26.1:53057] richdocumentscode (proxy.php) error exit, PID: 410389, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:39:20.483619 2024] [php:notice] [pid 410283] [client 192.168.26.1:53055] richdocumentscode (proxy.php) error exit, PID: 410283, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:39:21.755396 2024] [php:notice] [pid 410389] [client 192.168.26.1:53057] richdocumentscode (proxy.php) error exit, PID: 410389, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:56:51.396507 2024] [php:notice] [pid 411111] [client 192.168.26.1:60568] richdocumentscode (proxy.php) error exit, PID: 411111, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:56:52.634899 2024] [php:notice] [pid 411141] [client 192.168.26.1:60573] richdocumentscode (proxy.php) error exit, PID: 411141, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:56:53.873041 2024] [php:notice] [pid 411084] [client 192.168.26.1:60575] richdocumentscode (proxy.php) error exit, PID: 411084, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:56:55.122409 2024] [php:notice] [pid 411141] [client 192.168.26.1:60573] richdocumentscode (proxy.php) error exit, PID: 411141, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
[Mon Jan 15 15:56:59.515066 2024] [php:notice] [pid 411084] [client 192.168.26.1:60575] richdocumentscode (proxy.php) error exit, PID: 411084, Message: No content in reply from coolwsd. Is SSL enabled in error ?
[Mon Jan 15 17:00:30.711615 2024] [php:notice] [pid 413108] [client 192.168.26.1:58934] richdocumentscode (proxy.php) error exit, PID: 413108, Message: The param should be 'status' or 'req=...', but is: 'ui_theme=light'
PASTE HERE
{"reqId":"lhRZkyStOiHygLo0mGQe","level":3,"time":"2024-01-15T18:23:15+08:00","remoteAddr":"","user":"--","app":"activity","method":"","url":"--","message":"Failed sending activity email to user \"l.benas@psa.gov.ph\"","userAgent":"--","version":"25.0.13.2","exception":{"Exception":"Swift_TransportException","Message":"Failed to authenticate on SMTP server with username \"xxxxx\" using 1 possible authenticators. Authenticator LOGIN returned Expected response code 250 but got an empty response.","Code":0,"Trace":[{"file":"/var/www/html/nextcloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/EsmtpTransport.php","line":371,"function":"afterEhlo","class":"Swift_Transport_Esmtp_AuthHandler","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php","line":148,"function":"doHeloCommand","class":"Swift_Transport_EsmtpTransport","type":"->"},{"file":"/var/www/html/nextcloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Mailer.php","line":65,"function":"start","class":"Swift_Transport_AbstractSmtpTransport","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/Mail/Mailer.php","line":191,"function":"send","class":"Swift_Mailer","type":"->"},{"file":"/var/www/html/nextcloud/apps/activity/lib/MailQueueHandler.php","line":415,"function":"send","class":"OC\\Mail\\Mailer","type":"->"},{"file":"/var/www/html/nextcloud/apps/activity/lib/MailQueueHandler.php","line":165,"function":"sendEmailToUser","class":"OCA\\Activity\\MailQueueHandler","type":"->"},{"file":"/var/www/html/nextcloud/apps/activity/lib/BackgroundJob/EmailNotification.php","line":61,"function":"sendEmails","class":"OCA\\Activity\\MailQueueHandler","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/BackgroundJob/Job.php","line":54,"function":"run","class":"OCA\\Activity\\BackgroundJob\\EmailNotification","type":"->"},{"file":"/var/www/html/nextcloud/lib/private/BackgroundJob/TimedJob.php","line":60,"function":"execute","class":"OC\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/html/nextcloud/cron.php","line":152,"function":"execute","class":"OC\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/html/nextcloud/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/Esmtp/AuthHandler.php","Line":191,"message":"Failed sending activity email to user \"{user}\"","CustomMessage":"Failed sending activity email to user \"xxxxx\""}}
{"reqId":"lhRZkyStOiHygLo0mGQe","level":2,"time":"2024-01-15T18:23:15+08:00","remoteAddr":"","user":"--","app":"activity","method":"","url":"--","message":"Failed sending activity email to user 'xxxxx'.","userAgent":"--","version":"25.0.13.2","data":{"app":"activity"}}
