I’ve got a problem with permissions on both normal folders and group folders, but the problem may be elsewhere, too.
First of all, the problem (NC27 still, together with Pg15):
I am the administrator of a group folder, but I cannot rename it, and I can also not delete it. The same goes for files inside the group folder(s) - there’s a whole tree hanging off from it.
I also wanted to grant someone in a group editor access to the folder, but that did not work, either, using File Access Control. With the Group Folder, I can add rules for the group and also rules for individuals that should have higher privileges - except, those elevated privileges for those individuals do not seem to have any effects. Thinking that the permissions from the various rules might not add up (the group basically has read-only permissions), I removed someone from the group in order to give them elevated permissions, but then, they could not see the group folder at all.
After reading a number of messages here and also bug reports on Github, I figured that this problem might be related to the Group Folder app, so I tried to replicate the setup with normal folders, but then found that I can’t add any of those elevated permissions at all, as if “File Access Control” worked with Group Folders exclusively.
Sharing something with a number of individuals does not appear to work, either, or at least, I found no way to add a variety of “Sharing” instructions to one folder.
It doesn’t matter whether I’m using a normal user account, or whether I’m logged in as the site administrator.
Do you have any suggestions, please?
