- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
34.0.4
Ubuntu 24.04.5
Apache 2.4.58
replace me
- PHP version (e.g, 8.3):
8.3
Yes
After upgrade from Nextcloud 28 to 34.0.3
Nextcloud web client
no
Server recently upgraded from Nextcloud 29.0 (very far behind!)
User edits file (normally Microsoft Word), and when tries to save work (either intermediary save or document close), Word reports error that the file is read-only, and that work must be saved to a different file name or location.
This is an intermittent issue. Sometimes, it’s possible to work without difficulties (even multiple saves).
I have not been able to replicate this one myself.
User has been running 34.0.3 of the client (and corresponding with 34.0.3 on the server), and upgraded to 34.0.4, when the server was upgraded to 34.0.4.
This is happening only through the Nextcloud client. Primary user is running MacOS 26.6.2 (and edits a lot of files). However, we’ve also seen it happen a couple of times with users running Windows 11 25H2.
When the read-only problem occurs, the file shows a lock icon in the web client, as well as in the MacOS Finder and the Windows Explorer. Sometimes, closing the file in Word is enough to release the lock, but we’ve seen occasions when a file stays locked, and the lock doesn’t clear until either the file is manually unlocked, or the lock eventually times out (hours later).
We’re not hosting the server, but working with a small hosting provider that has the server installed in a VPS (proxmox, I believe – definitely not Docker), but I think the setup is considered to be self-hosted. Just that I’m not doing the hosting myself.
I have not been able to replicate the problem.
No related is in the logs
PASTE
PASTE HERE
“system”: {
“instanceid”: “REMOVED SENSITIVE VALUE”,
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “34.0.4.1”,
“overwrite.cli.url”: “REMOVED SENSITIVE VALUE”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“htaccess.RewriteBase”: “/”,
“mail_smtpmode”: “smtp”,
“mail_sendmailmode”: “smtp”,
“mail_from_address”: “REMOVED SENSITIVE VALUE”,
“mail_domain”: “REMOVED SENSITIVE VALUE”,
“mail_smtphost”: “REMOVED SENSITIVE VALUE”,
“mail_smtpport”: “587”,
“mail_smtpauth”: 1,
“maintenance”: false,
“maintenance_window_start”: 1,
“loglevel”: 2,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“trashbin_retention_obligation”: “auto, 60”,
“theme”: “”,
“app_install_overwrite”: ,
“updater.secret”: “REMOVED SENSITIVE VALUE”
- activity: 7.0.0
- app_api: 34.0.0
- appstore: 1.0.0
- bruteforcesettings: 7.0.0
- circles: 34.0.0
- cloud_federation_api: 1.18.0
- comments: 1.24.0
- contactsinteraction: 1.15.0
- dashboard: 7.14.0
- dav: 1.40.0
- federatedfilesharing: 1.24.0
- files: 2.6.0
- files_downloadlimit: 5.2.0
- files_lock: 34.0.1
- files_pdfviewer: 7.0.0
- files_reminders: 1.7.0
- files_sharing: 1.26.0
- files_trashbin: 1.24.0
- files_versions: 1.27.0
- firstrunwizard: 7.0.0-dev.0
- logreader: 7.0.0
- lookup_server_connector: 1.22.0
- nextcloud_announcements: 6.0.0
- notifications: 7.0.0-dev.1
- oauth2: 1.22.0
- office: 1.0.0
- password_policy: 6.0.0-dev.0
- photos: 7.0.0
- privacy: 6.0.0-dev.1
- profile: 1.3.0
- provisioning_api: 1.24.0
- recommendations: 7.0.0
- related_resources: 5.0.0-dev.0
- serverinfo: 6.0.0
- settings: 1.17.0
- sharebymail: 1.24.0
- support: 6.0.0
- survey_client: 6.0.0-dev.0
- systemtags: 1.24.0
- text: 8.0.0
- theming: 2.9.0
- twofactor_backupcodes: 1.23.0
- twofactor_totp: 16.0.0
- updatenotification: 1.24.0
- user_status: 1.14.0
- viewer: 7.0.0-dev.0
- webhook_listeners: 1.6.0
- workflowengine: 2.16.0
Disabled: - admin_audit: 1.24.0
- encryption: 2.22.0
- federation: 1.24.0 (installed 1.19.0)
- files_automatedtagging: 1.19.0 (installed 1.19.0)
- files_external: 1.26.0
- flow_notifications: 5.0.0 (installed 5.0.0)
- suspicious_login: 12.0.0-dev.0
- twofactor_nextcloud_notification: 8.0.0
- user_ldap: 1.25.0
- weather_status: 1.14.0 (installed 1.9.0)
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
