I currently consider to set up a Nextcloud instance as connection point between an unsecured company network (industry machines) and the secured network next to it.
Example:
Unsecured host copies files to a Nextcloud share, this Nextcloud instace scans the files and copies them over to a secured share (if the files are clean ;-)).
Is this possible with Nextcloud an ClamAV? Does ClamAV also scans files which are transferred over samba instead of the web gui?
Or should I create a script which checks the files on the system itself and copies them if they are clean?
Does anyone has better ideas?
Regards
Sh1ndy
