Hallo Zusammen,
ich habe nach der installation auf einem Debian mit Apache mehrere Fehler.
Ich fange einfach mal mit Folgendem an:
{"reqId":"LhPpSBlkbPHzeNewSnSk","level":3,"time":"2023-12-28T17:41:11+00:00","remoteAddr":"87.164.239.135","user":"nc-admin","app":"index","method":"GET","url":"/index.php/apps/theming/icon?v=57fafcc4","message":"Could not create folder \"/appdata_oc0vmps4hpzc/theming/global\"","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:121.0) Gecko/20100101 Firefox/121.0","version":"28.0.1.1","exception":{"Exception":"OCP\\Files\\NotPermittedException","Message":"Could not create folder \"/appdata_oc0vmps4hpzc/theming/global\"","Code":0,"Trace":[{"file":"/var/www/nextcloud/lib/private/Files/AppData/AppData.php","line":147,"function":"newFolder","class":"OC\\Files\\Node\\Folder","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ImageManager.php","line":367,"function":"newFolder","class":"OC\\Files\\AppData\\AppData","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/ImageManager.php","line":101,"function":"getRootFolder","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/var/www/nextcloud/apps/theming/lib/Controller/IconController.php","line":168,"function":"getImage","class":"OCA\\Theming\\ImageManager","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"getTouchIcon","class":"OCA\\Theming\\Controller\\IconController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1069,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":39,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/lib/private/Files/Node/Folder.php","Line":162,"message":"Could not create folder \"/appdata_oc0vmps4hpzc/theming/global\"","exception":[],"CustomMessage":"Could not create folder \"/appdata_oc0vmps4hpzc/theming/global\""},"id":"659466ba90cde"}
Ich habe allerdings noch keinen schimmer was er überhaupt von mir will und wonach ich suchen soll.
Kann mir jemand einen Tip geben?
MFG
Jens
