mein nextcloud.log füllt sich mit:
OCP\AppFramework\QueryException: Could not resolve encryptionManager! Class encryptionManager does not exist
System centos7
PHP 7.3.12 (fpm-fcgi) (built: Nov 19 2019 10:24:51)
Copyright © 1997-2018 The PHP Group
Zend Engine v3.3.12, Copyright © 1998-2018 Zend Technologies
with Zend OPcache v7.3.12, Copyright © 1999-2018, by Zend Technologies
apache Server version: Apache/2.4.43
Nextcloud Version 20.2
Seit dem Update auf 20.2 wird meine log-Datei mit der Fehlermeldung geflutet:
Error no app in context OCP\AppFramework\QueryException: Could not resolve encryptionManager! Class encryptionManager does not exist
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 126:
OC\AppFramework\Utility\SimpleContainer->resolve("encryptionManager")
/var/www/html/nextcloud/lib/private/ServerContainer.php - line 156:
OC\AppFramework\Utility\SimpleContainer->query("encryptionManager", true)
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 96:
OC\ServerContainer->query("encryptionManager")
<<closure>>
OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}("*** sensiti ... *")
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 101:
array_map(Closure {}, [ "*** sensi ... "])
/var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php - line 109:
OC\AppFramework\Utility\SimpleContainer->buildClass(ReflectionCl ... "})
OC\AppFramework\Utility\SimpleContainer->resolve("OCA\\CMSPic ... r")
OC\AppFramework\Utility\SimpleContainer->query("OCA\\CMSPic ... r", true)
/var/www/html/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php - line 66:
OC\ServerContainer->query("OCA\\CMSPic ... r")
/var/www/html/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php - line 251:
OC\EventDispatcher\ServiceEventListener->__invoke(OCP\EventDis ... {}, "OCA\\Files_ ... s", Symfony\Comp ... {})
/var/www/html/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php - line 73:
Symfony\Component\EventDispatcher\EventDispatcher->callListeners([ Closure {},Closure {}], "OCA\\Files_ ... s", OCP\EventDis ... {})
/var/www/html/nextcloud/lib/private/EventDispatcher/EventDispatcher.php - line 86:
Symfony\Component\EventDispatcher\EventDispatcher->dispatch(OCP\EventDis ... {}, "OCA\\Files_ ... s")
/var/www/html/nextcloud/lib/private/EventDispatcher/SymfonyAdapter.php - line 72:
OC\EventDispatcher\EventDispatcher->dispatch("OCA\\Files_ ... s", OCP\EventDis ... {})
/var/www/html/nextcloud/apps/files_external/lib/Service/BackendService.php - line 118:
OC\EventDispatcher\SymfonyAdapter->dispatch("OCA\\Files_ ... s", OCP\EventDis ... {})
/var/www/html/nextcloud/apps/files_external/lib/Service/BackendService.php - line 125:
OCA\Files_External\Service\BackendService->callForRegistrations()
/var/www/html/nextcloud/apps/files_external/lib/Service/BackendService.php - line 230:
OCA\Files_External\Service\BackendService->loadBackendProviders()
/var/www/html/nextcloud/apps/files_external/lib/Service/StoragesService.php - line 304:
OCA\Files_External\Service\BackendService->getBackend("smb")
/var/www/html/nextcloud/apps/files_external/lib/Service/StoragesService.php - line 104:
OCA\Files_External\Service\StoragesService->createStorage("/Kliniknetz", "smb", "password::logincredentials", { host: "s4m ... "}, { encrypt: t ... e}, [], [ "Domain Admins"], 100)
<<closure>>
OCA\Files_External\Service\StoragesService->getStorageConfigFromDBMount({ mount_id: ... }})
/var/www/html/nextcloud/apps/files_external/lib/Service/UserGlobalStoragesService.php - line 193:
array_map([ OCA\Files_ ... "], [ { mount_id ... }])
/var/www/html/nextcloud/apps/files_external/lib/Config/ConfigAdapter.php - line 128:
OCA\Files_External\Service\UserGlobalStoragesService->getAllStoragesForUser()
/var/www/html/nextcloud/lib/private/Files/Config/MountProviderCollection.php - line 109:
OCA\Files_External\Config\ConfigAdapter->getMountsForUser(OC\User\User {}, OC\Files\Sto ... {})
/var/www/html/nextcloud/lib/private/Files/Filesystem.php - line 452:
OC\Files\Config\MountProviderCollection->addMountForUser(OC\User\User {}, OC\Files\Mount\Manager {})
/var/www/html/nextcloud/lib/private/Files/Filesystem.php - line 377:
OC\Files\Filesystem::initMountPoints("125132FC-FA ... E")
/var/www/html/nextcloud/lib/private/legacy/OC_Util.php - line 322:
OC\Files\Filesystem::init("125132FC-FA ... E", "/125132FC-F ... s")
/var/www/html/nextcloud/lib/private/Files/Filesystem.php - line 355:
OC_Util::setupFS()
/var/www/html/nextcloud/lib/private/Files/View.php - line 1152:
OC\Files\Filesystem::resolvePath("/files_encr ... y")
/var/www/html/nextcloud/lib/private/Files/View.php - line 543:
OC\Files\View->basicOperation("file_exists", "/files_encr ... y")
/var/www/html/nextcloud/lib/private/Encryption/Keys/Storage.php - line 270:
OC\Files\View->file_exists("/files_encr ... y")
/var/www/html/nextcloud/lib/private/Encryption/Keys/Storage.php - line 230:
OC\Encryption\Keys\Storage->getKey("/files_encr ... y")
/var/www/html/nextcloud/lib/private/Encryption/Keys/Storage.php - line 122:
OC\Encryption\Keys\Storage->getKeyWithUid("/files_encr ... y", null)
/var/www/html/nextcloud/apps/encryption/lib/KeyManager.php - line 615:
OC\Encryption\Keys\Storage->getSystemUserKey("pubShare_91f5030e.publicKey", "OC_DEFAULT_MODULE")
/var/www/html/nextcloud/apps/encryption/lib/KeyManager.php - line 171:
OCA\Encryption\KeyManager->getPublicShareKey()
/var/www/html/nextcloud/apps/encryption/lib/Users/Setup.php - line 87:
OCA\Encryption\KeyManager->validateShareKey()
/var/www/html/nextcloud/apps/encryption/lib/AppInfo/Application.php - line 73:
OCA\Encryption\Users\Setup->setupSystem()
/var/www/html/nextcloud/apps/encryption/appinfo/app.php - line 37:
OCA\Encryption\AppInfo\Application->setUp()
/var/www/html/nextcloud/lib/private/legacy/OC_App.php - line 289:
require_once("/var/www/ht ... p")
/var/www/html/nextcloud/lib/private/legacy/OC_App.php - line 171:
OC_App::requireAppFile(OCA\Encrypti ... {})
/var/www/html/nextcloud/lib/private/legacy/OC_App.php - line 131:
OC_App::loadApp("encryption")
/var/www/html/nextcloud/lib/base.php - line 993:
OC_App::loadApps()
/var/www/html/nextcloud/index.php - line 37:
OC::handleRequest()
Ich habe nach der Empfehlung in “Übersicht” das alte Encryption in der config.php
abgeschaltet:
‘encryption.legacy_format_support’ => false,
‘encryption.key_storage_migrated’ => false,
