- Nextcloud Version: 27.1.1
- PHP Version: 8.1
- Datenbank: MariaDB 10.3
- Hosting: Uberspace (shared server)
- Betriebssystem: Uberspace 7.15.5 (Linux 3.10.0-1160.83.1.el7.x86_64)
Hallo zusammen!
Beim Löschen einer *.tar.gz Datei in der Nextcloud Web-GUI erhalte ich folgenden Fehlermeldung:
[no app in context] Fehler: OCA\DAV\Connector\Sabre\Exception\FileLocked: "Sicherungen (Backups)/WLAN-Zugänge.tar.gz" is locked, existing lock on file: 2 shared locks at <<closure>>
0. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1137
OCA\DAV\Connector\Sabre\File->put("*** sensitive parameters replaced ***")
1. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 492
Sabre\DAV\Server->updateFile("*** sensitive parameters replaced ***")
2. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPut(["Sabre\\HTTP\\Request"], ["Sabre\\HTTP\\Response"])
3. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
Sabre\DAV\Server->emit("method:PUT", [["Sabre\\HTTP\\ ... ]])
4. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod(["Sabre\\HTTP\\Request"], ["Sabre\\HTTP\\Response"])
5. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start()
6. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Server.php line 365
Sabre\DAV\Server->exec()
7. /Pfad/zu/meiner/Nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
8. /Pfad/zu/meiner/Nextcloud/remote.php line 172
require_once("/var/www/virtua ... p")
Caused by:
OCP\Lock\LockedException: "Sicherungen (Backups)/WLAN-Zugänge.tar.gz" is locked, existing lock on file: 2 shared locks at <<closure>>
0. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Connector/Sabre/Node.php line 413
OC\Files\View->changeLock("/Sicherungen (B ... z", 2)
1. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Connector/Sabre/File.php line 191
OCA\DAV\Connector\Sabre\Node->changeLock(2)
2. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1137
3. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 492
4. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
5. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
6. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
7. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
8. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Server.php line 365
9. /Pfad/zu/meiner/Nextcloud/apps/dav/appinfo/v2/remote.php line 35
10. /Pfad/zu/meiner/Nextcloud/remote.php line 172
Caused by:
OCP\Lock\LockedException: "files/eab9e9e87a1e0d7f739635f48f7ac296"("files/Sicherungen (Backups)/WLAN-Zugänge.tar.gz") is locked, existing lock on file: 2 shared locks at <<closure>>
0. /Pfad/zu/meiner/Nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 629
OC\Files\Storage\Common->changeLock("files/Sicherung ... z", 2, ["OC\\Lock\\MemcacheLockingProvider"])
1. /Pfad/zu/meiner/Nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 629
OC\Files\Storage\Wrapper\Wrapper->changeLock("files/Sicherung ... z", 2, ["OC\\Lock\\MemcacheLockingProvider"])
2. /Pfad/zu/meiner/Nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 629
3. /Pfad/zu/meiner/Nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 629
4. /Pfad/zu/meiner/Nextcloud/lib/private/Files/View.php line 1978
5. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Connector/Sabre/Node.php line 413
6. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Connector/Sabre/File.php line 191
7. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1137
8. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 492
9. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
10. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
11. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
12. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
13. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Server.php line 365
14. /Pfad/zu/meiner/Nextcloud/apps/dav/appinfo/v2/remote.php line 35
15. /Pfad/zu/meiner/Nextcloud/remote.php line 172
Caused by:
OCP\Lock\LockedException: "files/eab9e9e87a1e0d7f739635f48f7ac296" is locked, existing lock on file: 2 shared locks at <<closure>>
0. /Pfad/zu/meiner/Nextcloud/lib/private/Files/Storage/Common.php line 831
OC\Lock\MemcacheLockingProvider->changeLock("files/eab9e9e87a1e0d7f739635f48f7ac296", 2)
4. /Pfad/zu/meiner/Nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 629
5. /Pfad/zu/meiner/Nextcloud/lib/private/Files/View.php line 1978
6. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Connector/Sabre/Node.php line 413
7. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Connector/Sabre/File.php line 191
8. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1137
9. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 492
10. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
11. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
12. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
13. /Pfad/zu/meiner/Nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
14. /Pfad/zu/meiner/Nextcloud/apps/dav/lib/Server.php line 365
15. /Pfad/zu/meiner/Nextcloud/apps/dav/appinfo/v2/remote.php line 35
16. /Pfad/zu/meiner/Nextcloud/remote.php line 172
PUT /remote.php/dav/files/*** my name ***/Sicherungen%20(Backups)/WLAN-Zug%C3%A4nge.tar.gz
from *** private IPv6 *** by *** my name *** at 2023-09-29T06:53:13+00:00
Auf dem Server habe ich diesen Lösungsansatz versucht:
nano config/config.php→ Änderung:'maintenance' => true,mysql nextcloudMariaDB [nextcloud]> DELETE FROM oc_file_locks WHERE 1;Query OK, 0 rows affected (0,005 sec)MariaDB [nextcloud]> exitnano config/config.php→ Änderung:'maintenance' => false,
Beim erneuten Lösch-Versuch in der Nextcloud Web-GUI erhalte ich jedoch den gleichen Fehler wie zuvor. Auch php occ files:scan --all und php occ files:cleanup habe ich ausgeführt: Der Fehler bleibt bestehen. Habt ihr noch Ideen?
