Nextcloud Hub 9 (30.0.5)
Linux 6.8.12-7-pve x86_64
replace me
Nginx Proxy Manager v2.12.2
- PHP version (e.g, 8.3):
8.3.15
Yes
while setting up OpenAI und LocalAI-Integration
AIO
No
I set up Ollama as an HTTP service and modified the Nextcloud config (config.php) to accept connections from HTTP servers by adding:
'allow_local_remote_servers' => true,
I am not using NGINX for Ollama, just accessing it via its IP and port. I can successfully curl the Ollama API and get correct responses.
Issue:
Despite this, Nextcloud cannot fetch models from Ollama and returns the following error:
Fehler beim Laden von Modellen
Error getting model enum values
exception Authenticated ciphertext could not be decoded.
Ollama itself is working fine when tested via curl, but Nextcloud still does not recognize the models.
Set up Ollama as an HTTP service on a self-hosted Docker instance without HTTPS.
- Ollama is running and accessible via:
http://<server-ip>:11434/v1 - Testing with
curlconfirms it is working:curl http://<server-ip>:11434/v1/models- Returns a valid JSON response with the list of models.
Modify Nextcloud configuration to allow HTTP connections:
- Access the Nextcloud container:
docker exec -it nextcloud-aio-nextcloud bash - Edit
config.php:nano /var/www/html/config/config.php - Add this line inside the
$CONFIGarray:'allow_local_remote_servers' => true, - Save and exit, then restart Nextcloud:
docker restart nextcloud-aio-nextcloud
Configure Nextcloud AI integration:
- Go to Nextcloud Settings → Administration → AI Backend.
- Set the API URL to:
http://<server-ip>:11434/v1 - Click Save.
Check for errors:
- Nextcloud fails to connect to the Ollama models and displays:
Error getting model enum values exception Authenticated ciphertext could not be decoded. - Despite the error,
curlrequests to the Ollama API still work fine outside Nextcloud.
Warnung integration_openai
Exception Authenticated ciphertext could not be decoded.
'one-click-instance' => true,
'one-click-instance.user-limit' => 100,
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'check_data_directory_permissions' => false,
'redis' =>
'host' => 'nextcloud-aio-redis',
'password' => 'xxxxxxxxxxxxxxxxxxxxxx',
'port' => 6379,
'overwritehost' => 'xxxxxxxxxxxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxI',
'secret' => 'xxxxxxxxxxxxxxxx',
0 => 'localhost',
1 => 'xxxxxxxxxxxxxxxxxxxx',
'datadirectory' => '/mnt/ncdata',
'dbtype' => 'pgsql',
'version' => '30.0.5.1',
'overwrite.cli.url' => 'xxxxxxxxxxxxx',
'dbname' => 'nextcloud_database',
'dbhost' => 'nextcloud-aio-database:5432',
'dbuser' => 'xxxxxxxxxxxxxxxx',
'dbpassword' => 'xxxxxxxxxxxxxxxxxxxx',
'instanceid' => 'xxxxxxxxxxxxx',
'loglevel' => 2,
'log_type' => 'file',
'logfile' => '/var/www/html/data/nextcloud.log',
'log_rotate_size' => 10485760,
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'preview_max_x' => 2048,
'preview_max_y' => 2048,
'jpeg_quality' => 60,
'enabledPreviewProviders' =>
1 => 'OC\\Preview\\Image',
2 => 'OC\\Preview\\MarkDown',
3 => 'OC\\Preview\\MP3',
4 => 'OC\\Preview\\TXT',
5 => 'OC\\Preview\\OpenDocument',
6 => 'OC\\Preview\\Movie',
7 => 'OC\\Preview\\Krita',
0 => 'OC\\Preview\\Imaginary',
23 => 'OC\\Preview\\ImaginaryPDF',
'enable_previews' => true,
'mail_smtpmode' => 'smtp',
'versions_retention_obligation' => 'auto, 30',
'activity_expire_days' => 30,
'share_folder' => '/Shared',
'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
'updatedirectory' => '/nc-updater',
'maintenance_window_start' => 100,
'davstorage.request_timeout' => 3600,
'documentation_url.server_logs' => 'https://github.com/nextcloud/all-in-one/discussions/5425',
'dbpersistent' => false,
'auth.bruteforce.protection.enabled' => true,
'ratelimit.protection.enabled' => true,
'files_external_allow_create_new_local' => false,
'trusted_proxies' =>
0 => '127.0.0.1',
1 => '::1',
10 => '172.22.0.0/16',
'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
'preview_imaginary_key' => 'xxxxxxxxxxxxxxxxxxxxx',
'app_install_overwrite' =>
0 => 'otpmanager',
'openai_api_key' => '',
'mail_from_address' => 'xxxxxxxxxxxxxxxx',
'mail_domain' => 'xxxxxxxxxxxxxxxx',
'mail_smtphost' => 'xxxxxxxxxxxxx',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'xxxxxxxxxxxxxxxxxxx',
'mail_smtppassword' => 'xxxxxxxxxxxxxxxxxxxxxxxx',
