Originally published at: February maintenance updates for Nextcloud Hub - Nextcloud
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 10 or Nextcloud Hub 25 Autumn, we strongly recommend you to update to version 31.0.14 and 32.0.6 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
The maintenance updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
- Nextcloud Hub 10 (version 31.0.14, EOL)
- Nextcloud Hub 25 Autumn (version 32.0.6)
Nextcloud Hub 10 (31x) reaches End of Life. What does it mean?
Major versions that have reached their End of Life no longer receive further bug fixes or security updates. Support for major releases may be extended through Nextcloud Enterprise offered by Nextcloud developers via Nextcloud GmbH. For more details to help with planning your updates, check the documentation page.
Regain your digital autonomy with Nextcloud Hub 26 Winter
Our latest release of Nextcloud Hub 26 Winter is here! Discover the latest Nextcloud features.
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
