example
longer
example
here
Nextcloud version (eg, 20.0.5): 27.1.3
Operating system and version (eg, Ubuntu 20.04): Ubuntu 22.04
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.58
PHP version (eg, 7.4): PHP 8.1.26
Nextcloud Ios app offers the possibility to use Voice Memo to record audio and upload it to Nextcloud. So far all good but the issue is that the format of the audio is m4a and Nextcloud can not play it. I tested with Audio Player and Music app also and it does not work. Also tested the audio files on another Nextcloud setup and still the same issue. I would really appreciate any feedback you might have regarding the issue. Thanks a lot!
- Record with Voice Memo from Ios nextcloud client
- Open it on Nextcloud in the browser
- Error loading file. The extension of the file is m4a
Nothing related to this issue
'instanceid' => ' *******',
'passwordsalt' => '*****',
'secret' => '*****',
0 => '***',
1 => '****',
'datadirectory' => '/var/www/data',
'version' => '27.1.3.2',
'overwrite.cli.url' => '****,
'dbname' => '****',
'dbhost' => 'localhost',
'dbuser' => '****',
'dbpassword' => '*****',
'defaultapp' => 'files',
'twofactor_enforced' => 'true',
'redis' =>
'host' => '/run/redis/redis-server.sock',
'port' => 0,
'timeout' => 0.0,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => '****',
'mail_domain' => '*****,
'mail_smtpauth' => 1,
'mail_smtphost' => ****',
'mail_smtpport' => '465',
'mail_smtpname' => '*****',
'mail_smtppassword' => '****',
'default_phone_region' => 'GB',
'theme' => '',
'loglevel' => 0,
'app_install_overwrite' =>
0 => 'external',
1 => 'calendar',
Nothing related to the issue
