Nextcloud version (eg, 20.0.5): 22.2.3
Operating system and version (eg, Ubuntu 20.04): Ubuntu 18.04
Apache or nginx version (eg, Apache 2.4.25): Nginx 1.14.0
PHP version (eg, 7.4): 8.0 (also tried 8.1, 7.4, 7.3)
- Install Nextcloud
- Set CRON instead of AJAX/Webcron
- Type
sudo -u www-data php -f /var/www/html/nextcloud/cron.php.
After performing these actions, no errors appear there.
'instanceid' => 'hidden',
'passwordsalt' => 'hidden',
'secret' => 'hidden',
0 => 'hidden',
'datadirectory' => '/var/www/html/nextcloud/data',
'dbtype' => 'sqlite3',
'version' => '22.2.3.0',
'overwrite.cli.url' => 'hidden',
'memcache.distributed' => '\\OC\\Memcache\\APCu',
'memcache.locking' => '\\OC\\Memcache\\APCu',
'app_install_overwrite' =>
0 => 'documents',
After performing these actions, no errors appear there. This is not a problem with the web server.
I wanted to set up News on my instance. RSS feeds needs to be updating, which I wanted to use CRON for (AJAX and Webcron are not supported). I followed this guide (https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/background_jobs_configuration.html) but I ran into a problem.
When I tried to execute command sudo -u www-data php -f /var/www/html/nextcloud/cron.php to test the operation, I got an error:
Doctrine\DBAL\Exception: Failed to connect to the database: An exception occurred in the driver: could not find driver in /var/www/html/nextcloud/lib/private/DB/Connection.php:87
Stack trace:
#0 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1519): OC\DB\Connection->connect()
#1 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1041): Doctrine\DBAL\Connection->getWrappedConnection()
#2 /var/www/html/nextcloud/lib/private/DB/Connection.php(236): Doctrine\DBAL\Connection->executeQuery()
#3 /var/www/html/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(345): OC\DB\Connection->executeQuery()
#4 /var/www/html/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/html/nextcloud/lib/private/AppConfig.php(344): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/html/nextcloud/lib/private/AppConfig.php(109): OC\AppConfig->loadConfigValues()
#7 /var/www/html/nextcloud/lib/private/AppConfig.php(300): OC\AppConfig->getApps()
#8 /var/www/html/nextcloud/lib/private/legacy/OC_App.php(971): OC\AppConfig->getValues()
#9 /var/www/html/nextcloud/lib/private/Server.php(687): OC_App::getAppVersions()
#10 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}()
#11 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#12 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet()
#13 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#14 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#15 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(182): OC\AppFramework\Utility\SimpleContainer->get()
#16 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#17 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#18 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet()
#19 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#20 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#21 /var/www/html/nextcloud/lib/private/Server.php(1064): OC\AppFramework\Utility\SimpleContainer->get()
#22 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}()
#23 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#24 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet()
#25 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#26 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#27 /var/www/html/nextcloud/lib/private/Server.php(2024): OC\AppFramework\Utility\SimpleContainer->get()
#28 /var/www/html/nextcloud/lib/private/Files/View.php(118): OC\Server->getLockingProvider()
#29 /var/www/html/nextcloud/lib/private/Server.php(435): OC\Files\View->__construct()
#30 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(160): OC\Server->OC\{closure}()
#31 /var/www/html/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}()
#32 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(127): Pimple\Container->offsetGet()
#33 /var/www/html/nextcloud/lib/private/ServerContainer.php(136): OC\AppFramework\Utility\SimpleContainer->query()
#34 /var/www/html/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query()
#35 /var/www/html/nextcloud/lib/private/Server.php(1387): OC\AppFramework\Utility\SimpleContainer->get()
#36 /var/www/html/nextcloud/lib/base.php(594): OC\Server->boot()
#37 /var/www/html/nextcloud/lib/base.php(1089): OC::init()
#38 /var/www/html/nextcloud/cron.php(42): require_once('...')
#39 {main}
Initially, I was using PHP 8.1, but in this case, when I tried to execute the above command, the information appeared that my version of Nextcloud does not support this version of PHP yet. I downgraded PHP and got this error.
As I am using APC, I also tried to add --define apc.enable_cli=0 to the end of the command, but the problem persists.
I only need CRON to update RSS feeds so I tried to use this one as well: GitHub - nextcloud/news-updater: Fast, parallel feed updater for the News app; written in Python, but when I tried nextcloud-news-updater /var/www/html/nextcloud, an error appeared:
2022-03-09 16:55:05,138 - Nextcloud News Updater - ERROR - Command '['php', '-f', '/var/www/html/nextcloud/occ', 'news:updater:before-update']' returned non-zero exit status 1.: Trying again in 30 seconds
Traceback (most recent call last):
File "/usr/local/lib/python3.6/dist-packages/nextcloud_news_updater/api/updater.py", line 69, in run
self.before_update()
File "/usr/local/lib/python3.6/dist-packages/nextcloud_news_updater/api/cli.py", line 103, in before_update
self.cli.run(self.api.before_cleanup_command)
File "/usr/local/lib/python3.6/dist-packages/nextcloud_news_updater/api/cli.py", line 12, in run
return check_output(commands)
File "/usr/lib/python3.6/subprocess.py", line 356, in check_output
**kwargs).stdout
File "/usr/lib/python3.6/subprocess.py", line 438, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['php', '-f', '/var/www/html/nextcloud/occ', 'news:updater:before-update']' returned non-zero exit status 1.
^[[A^[[A^CTraceback (most recent call last):
**kwargs).stdout
During handling of the above exception, another exception occurred:
File "/usr/local/bin/nextcloud-news-updater", line 11, in <module>
load_entry_point('nextcloud-news-updater==11.0.0', 'console_scripts', 'nextcloud-news-updater')()
File "/usr/local/lib/python3.6/dist-packages/nextcloud_news_updater/__main__.py", line 26, in main
container.resolve(Updater).run()
File "/usr/local/lib/python3.6/dist-packages/nextcloud_news_updater/api/updater.py", line 99, in run
time.sleep(30)
I am using sqlite database. I know this is discouraged, but I’m using it on such a small scale that I’d rather not put MySQL server specifically for it. The file owncloud.db permission is -rw-r - r-- and is owned by www-data.
Apart from that, I did not notice any errors when using the instance.
Has anyone encountered such a problem or know how to solve it?
