Hi, I’m completely newbe so sorry. I’m tring to install nextcloud on Debian 12.4 (kernel 6.6.3) operation system on my NAS Zyxel 325v2 (Marvell ARMv5 processor) 1,Ghz, 512 MB RAM and I encountered problem
during strting MariaDB server (fresh installation). When installing mariadb and mariadb-client, I get the message as below.
root@debian:/etc/ssh# apt install mariadb-server
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
The following additional packages will be installed:
libmariadb3 mariadb-client mariadb-client-core mariadb-common
mariadb-server-core
Suggested packages:
mailx mariadb-test netcat-openbsd
Recommended packages:
libdbd-mariadb-perl | libdbd-mysql-perl libterm-readkey-perl
libhtml-template-perl mariadb-plugin-provider-bzip2
mariadb-plugin-provider-lz4 mariadb-plugin-provider-lzma
mariadb-plugin-provider-lzo mariadb-plugin-provider-snappy pv
The following NEW packages will be installed:
libmariadb3 mariadb-client mariadb-client-core mariadb-common mariadb-server
mariadb-server-core
0 upgraded, 6 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/12.8 MB of archives.
After this operation, 161 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Preconfiguring packages …
Selecting previously unselected package mariadb-common.
(Reading database … 36138 files and directories currently installed.)
Preparing to unpack …/mariadb-common_1%3a10.11.4-1~deb12u1_all.deb …
Unpacking mariadb-common (1:10.11.4-1~deb12u1) …
Selecting previously unselected package libmariadb3:armel.
Preparing to unpack …/libmariadb3_1%3a10.11.4-1~deb12u1_armel.deb …
Unpacking libmariadb3:armel (1:10.11.4-1~deb12u1) …
Selecting previously unselected package mariadb-client-core.
Preparing to unpack …/mariadb-client-core_1%3a10.11.4-1~deb12u1_armel.deb …
Unpacking mariadb-client-core (1:10.11.4-1~deb12u1) …
Selecting previously unselected package mariadb-client.
Preparing to unpack …/mariadb-client_1%3a10.11.4-1~deb12u1_armel.deb …
Unpacking mariadb-client (1:10.11.4-1~deb12u1) …
Selecting previously unselected package mariadb-server-core.
Preparing to unpack …/mariadb-server-core_1%3a10.11.4-1~deb12u1_armel.deb …
Unpacking mariadb-server-core (1:10.11.4-1~deb12u1) …
Setting up mariadb-common (1:10.11.4-1~deb12u1) …
update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Selecting previously unselected package mariadb-server.
(Reading database … 36381 files and directories currently installed.)
Preparing to unpack …/mariadb-server_1%3a10.11.4-1~deb12u1_armel.deb …
Unpacking mariadb-server (1:10.11.4-1~deb12u1) …
Setting up libmariadb3:armel (1:10.11.4-1~deb12u1) …
Setting up mariadb-server-core (1:10.11.4-1~deb12u1) …
Setting up mariadb-client-core (1:10.11.4-1~deb12u1) …
Setting up mariadb-client (1:10.11.4-1~deb12u1) …
Setting up mariadb-server (1:10.11.4-1~deb12u1) …
Stopping MariaDB database server: mariadbd.
/usr/bin/deb-systemd-helper: error: systemctl preset failed on mariadb.service: No such file or directory
Starting MariaDB database server: mariadbd . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . failed!
invoke-rc.d: initscript mariadb, action “start” failed.
dpkg: error processing package mariadb-server (–configure):
installed mariadb-server package post-installation script subprocess returned error exit status 1
Processing triggers for man-db (2.11.2-2) …
Processing triggers for libc-bin (2.36-9+deb12u4) …
Errors were encountered while processing:
mariadb-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
I have no error on /var/log/mysql because there is no such directory. It looks like installation was interrupted and log file was not created. But on /var/log/journal/mariadb.service.log I see something like this :
ERROR:systemctl:Unknown operation unset-enviroment.
When I type “apt upgrade” I see that 1 package was not fully installed or removed. Debian tries to install it but gets the error as above. I even try mysql_install_db, but with no success. I’m using an ARMv5 processor, so could this be a problem? How to fix it?
