extreme beginner - messed up my installation
    • I don't know? Nextcloud Spring 26
    • Fedora Server 44
    • I don't know?
    • I'm pretty sure I do not have a reverse proxy
    • I don't know?
    • Yes
    • A couple of hours ago
    • AIO v13.6.0
    • Yes? My domain is from Cloudflare
CONTEXT: My homelab has this configuration:
1.) 1 TB SSD
2.) mergerfs setup thing with three drives. The mergerfs drive thing is called /mnt/storage.
So, this all started because I was confused and lost (despite looking at documentation) on the fact that I installed nextcloud (using the docker master container. I didn’t use any run commands. I used the master container compose file) on my 1 TB SSD, but I wanted my files that I upload to live on /mnt/storage.
I decided to take a risk and stop all the nextcloud containers, delete them, move the compose file to /mnt/storage/Nextcloud. I could access the AIO just fine, but apache is stuck with this message from logs:
Message: Could not start container nextcloud-aio-apache: {"message":"failed to set up container networking: driver failed programming external connectivity on endpoint nextcloud-aio-apache (51f179c939c6f514637d4a70b917e9a337bb2d57443d1cd2480fdd5ec6d2bd1c): failed to bind host port 0.0.0.0:443/tcp: address already in use"}
I decided to make things worse and just remove all containers again and move back to the ssd, to which the same error message:
So now I’m stuck here. I don’t even know where to start.
Hi, it looks like you should probably start fresh. See GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance. · GitHub
thanks! i’ll try this. if this does work, I still wanted to figure out the solution to the initial problem i had: which was, if I had nextcloud installed on my ssd, I want it to have access to my /mnt/storage where i could put my uploaded files and such on there. is there something I can do before i reinstall AIO? something I need to put in the docker compose file?
See all-in-one/compose.yaml at 1c14b27090be1c22cc99a24cdd83dadb777e7004 · nextcloud/all-in-one · GitHub
I tried this, even the optional step. But it seems like I’m at a similar stuck point. Apache doesnt start, this is what it says in the logs for apache:
nc: getaddrinfo for host “nextcloud-aio-nextcloud” port 9000: Try again
edit: i have tried to restart fresh again
what i notice is that domaincheck doesnt automatically start, and so when i open up aio for the first time, i need to manually start domaincheck to continue.
after, i skip verification for the domain.
and then, once i build containers, the same issue persists:
2026-09-07T01:35:35.665012353Z Message: Could not start container nextcloud-aio-apache: {“message”:“failed to set up container networking: driver failed programming external connectivity on endpoint nextcloud-aio-apache (eccde2158cfec598a476cd47077627828361b1c3ff1dd31ff17a21c86d6adc00): failed to bind host port 0.0.0.0:443/tcp: address already in use”}
edit 2: i even did a fresh reinstall of my entire fedora 44 os. downloaded nextcloud as new. same issue:
2026-09-07T05:46:27.390267512Z Message: Could not start container nextcloud-aio-apache: {“message”:“failed to set up container networking: driver failed programming external connectivity on endpoint nextcloud-aio-apache (074ec2a52772099be1ae752d55ef183b77efbb5f2b223efc04bec4cc1bdf3e61): failed to bind host port 0.0.0.0:443/tcp: address already in use”}
alright, it appears that i solved it
the default installation method isn’t very compatible if you have multiple other docker containers running alongside nextcloud aio. i assume that if my server only had nextcloud aio, then we’d be good.
i found this: Tailscale (and Caddy as a sidecar) Reverse Proxy · nextcloud/all-in-one · Discussion #5439 · GitHub
so far, so good. it worked.
