I have external storage smg setup to have my users be able to access our network folders, everything is working fine except for one detail iv been having lately, when someone has for example an excel file opened over the local network on a computer and then someone on the nextcloud folder open the same file over nextcloud, the data doesnt sync, what i have to do is have both users close the file, rename that file and then have the nextcloud user open the file so it syncs as a new file, but i dont want this to be taken as a permanent solution if theres a way to avoid it.
My question is, can i fix that so it doesnt keep happening? if so, how? cause i mean if 2 ppl open such file over network, excel automatically notifies the 2nd user that the file is opened by another user, but such warning doesnt display when its opened on nextcloud and i guess thats whats happening, so if anyone have any solution to my issue, it would be awsome
to you have Installed redis and APCu?
In my way i had configured following:
config.php
‘memcache.local’ => ‘\OC\Memcache\APCu’,
‘filelocking.enabled’ => true,
‘memcache.distributed’ => ‘\OC\Memcache\Redis’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
this should locked the file for editing from 2 Persons, so it could not edited at the same time.
Can you explain how the file is open over nextcloud? Is it the Online Office or the Desktop Client and then Excel?
If it´s the Desktop Client you can allow the Desktop Client to sync the locking File to the nextcloud.
