Nextcloud version: 18.0.3
Operating system and version: CentOS 7
Apache or nginx version: Apache 2.4.41
PHP version: 7.2.29
The issue is:
Unable to add external storages. Error displays that reads: “smbclient” is not installed. Mounting of “SMB / CIFS”, “SMB / CIFS using OC login” is not possible. Please ask your system administrator to install it.
I have ran: yum install smbclient
Output of: smbd —version
Is: Version 4.9.1
Is this the first time you’ve seen this error? (Y/N):Y
Click Hamburger menu at the top-left, then on External Storages
stat(): stat failed for ftp://xxx:xxx@drive.mattlindsey.com:21/matt/ at /home/mlindsey/public_html/addon/mycloud/apps/files_external/lib/Lib/Storage/StreamWrapper.php#127
No related settings in config.php
No related logs
