Nextcloud Hub 6 (27.1.4)
Ubuntu 22.04.3 LTS
PHP 8.1.25
Hi, I have a problem with external storage. It says “smbclient is not installed” but I installed it. I looked on forums and none of the solutions seems to work. What should i do?
Ubuntu 22.04.3 LTS
PHP 8.1.25
I installed smbclient using apt and nextcloud using snap.
Aw, yes, that is why you’re having trouble.
Snap’s are (semi)confined environments. They don’t use things installed in host’s OS.
I think the community Snap suggests using SMB/CIFS via FUSE + Local External Storage: How to add samba shares and local shares · nextcloud-snap/nextcloud-snap Wiki · GitHub instead.
Related: Add samba (smb) support · Issue #60 · nextcloud-snap/nextcloud-snap · GitHub
