Dear community,
some weeks ago I installed NC 26.0.1. Since then I facing various Issues. The biggest “pain in the ass” is: external storages are not synchronized correctly. NC synchronises randomly some files and some not. Nor the cloud itself nor the clients (for Windows + Android) show the complete content of the connected folders. The storage is connected via SMB/CIFS. It all worked fine with NC 24.
Any idea how to fix the issue?
Best Joon
Details:
Nextcloud version: 26.0.1
Operating system and version : 22.04 LTS
nginx version: 1.18.0
PHP version: 8.2.7
mariaDB Version: 10.6.12
smbd Version: 4.15.13
External Storage support Version: 1.18.0
Is this the first time you’ve seen this error? Yes:
Steps to replicate it: The Issue is random, sometimes content is shown, sometimes not. After one failed trail of syncing the content is never shown anymore - it´s not deleted, but noted as 0B content.
[PHP] Fehler: Undefined array key "attributes" at /var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Wrapped/Parser.php#155
and:
[webdav] Fehler: Icewind\SMB\Exception\Exception: Malformed state response from server at <<closure>>
0. /var/www/nextcloud/apps/files_external/3rdparty/icewind/smb/src/Wrapped/Share.php line 217
Icewind\SMB\Wrapped\Parser->parseStat()
1. /var/www/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 191
Icewind\SMB\Wrapped\Share->stat()
2. /var/www/nextcloud/apps/files_external/lib/Lib/Storage/SMB.php line 666
OCA\Files_External\Lib\Storage\SMB->getFileInfo()
3. /var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 224
OCA\Files_External\Lib\Storage\SMB->file_exists()
4. /var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 224
OC\Files\Storage\Wrapper\Wrapper->file_exists()
5. /var/www/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php line 244
6. /var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php line 224
OC\Files\Storage\Wrapper\Availability->file_exists()
7. /var/www/nextcloud/lib/private/Files/View.php line 1350
8. /var/www/nextcloud/lib/private/Files/View.php line 1394
OC\Files\View->getCacheEntry()
9. /var/www/nextcloud/lib/private/Files/Node/Root.php line 205
OC\Files\View->getFileInfo()
10. /var/www/nextcloud/lib/private/Files/Node/Folder.php line 139
OC\Files\Node\Root->get()
11. /var/www/nextcloud/lib/private/Files/Node/Folder.php line 148
OC\Files\Node\Folder->get()
12. /var/www/nextcloud/apps/text/lib/Service/WorkspaceService.php line 26
OC\Files\Node\Folder->nodeExists()
13. /var/www/nextcloud/apps/text/lib/DAV/WorkspacePlugin.php line 110
OCA\Text\Service\WorkspaceService->getFile()
14. /var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
OCA\Text\DAV\WorkspacePlugin->propFind()
15. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1052
Sabre\DAV\Server->emit()
16. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 984
Sabre\DAV\Server->getPropertiesByNode()
17. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1662
Sabre\DAV\Server->getPropertiesIteratorForPath()
18. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 1647
Sabre\DAV\Server->writeMultiStatus()
19. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 346
Sabre\DAV\Server->generateMultiStatus()
20. /var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPropFind()
21. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 472
22. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 253
Sabre\DAV\Server->invokeMethod()
23. /var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php line 321
Sabre\DAV\Server->start()
24. /var/www/nextcloud/apps/dav/lib/Server.php line 366
Sabre\DAV\Server->exec()
25. /var/www/nextcloud/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
26. /var/www/nextcloud/remote.php line 172
require_once("/var/www/nextcl ... p")
