Just minutes after this the following happened.
Before my first post, I renamed the original folder “Scanner” to “Scanner1” just to see if that would do the trick. It didn’t. I then created a second External Storage entry as the Folder “Scanner” with the same login credentials. This one stayed empty, too.
I then wrote the post above.
I now deleted the secondly created External Storage entry “Scanner” because the groups weren’t assigned yet and just renamed “Scanner1” back to “Scanner”.
Now the folder got populated with all the scans (files in that folder on the FTP-Server)
So now on the FTP-server i did touch test.txt
and then chown scanner:scanner test.txt
with chmod 666 test.txt
and also wrote a line into it, then reloading the folder on the webinterface again and again, “test.txt” doesn’t show at all.
It is set to check for changes after every direct access.
So still, how to remedy this?
The log states now this after almost every file in that FTP-folder was accessed:
fclose(): FTP server error 451:451 Transfer aborted. Broken pipe at /usr/local/www/nextcloud/apps/files_external/3rdparty/icewind/streams/src/Wrapper.php#124
This seems to be related to the data transfermode being passive instead of active, which afaik the FTP-client has to do? So, how can I change that. Maybe that helps with all of this. Is it something in Nextcloud, or maybe even my PHP installation?
This error is also only shown in relation to my connected user account, which I am not logged in as (just the desktop-client which downloaded all the files onto my harddrive). I am currently only logged in as the admin account.
When I now delete a file via the desktop client, the deleted file still shows in the webinterface, and I get this error attributed to the user account that deleted the file:
{"reqId":"0FSOH64YouYY9dzH22Uy","remoteAddr":"217.253.***.***","app":"DeleteOrphanedItems","message":"0 orphaned comment read marks deleted","level":0,"time":"2016-09-09T03:03:42+02:00","method":"GET","url":"\/cron.php","user":"--"}
{"reqId":"Xms7CdMcVyXPEzmOWqVd","remoteAddr":"217.253.***.***","app":"admin_audit","message":"File deleted: \"\/Scanner\/doc01909420160823154301.pdf\"","level":1,"time":"2016-09-09T03:03:45+02:00","method":"DELETE","url":"\/remote.php\/webdav\/Scanner\/doc01909420160823154301.pdf","user":"user.name"}
{"reqId":"Xms7CdMcVyXPEzmOWqVd","remoteAddr":"217.253.***.***","app":"no app in context","message":"Could not find mount point, can't keep encryption keys","level":3,"time":"2016-09-09T03:03:45+02:00","method":"DELETE","url":"\/remote.php\/webdav\/Scanner\/doc01909420160823154301.pdf","user":"user.name"}
{"reqId":"Xms7CdMcVyXPEzmOWqVd","remoteAddr":"217.253.***.***","app":"PHP","message":"fclose(): FTP server error 451:451 Transfer aborted. Broken pipe\r\n at \/usr\/local\/www\/nextcloud\/apps\/files_external\/3rdparty\/icewind\/streams\/src\/Wrapper.php#124","level":3,"time":"2016-09-09T03:03:45+02:00","method":"DELETE","url":"\/remote.php\/webdav\/Scanner\/doc01909420160823154301.pdf","user":"user.name"}
{"reqId":"Xms7CdMcVyXPEzmOWqVd","remoteAddr":"217.253.***.***","app":"PHP","message":"fclose(): FTP server error 450:450 Transfer aborted. Link to file server lost\r\n at \/usr\/local\/www\/nextcloud\/apps\/files_external\/3rdparty\/icewind\/streams\/src\/Wrapper.php#124","level":3,"time":"2016-09-09T03:03:47+02:00","method":"DELETE","url":"\/remote.php\/webdav\/Scanner\/doc01909420160823154301.pdf","user":"user.name"}
{"reqId":"Xms7CdMcVyXPEzmOWqVd","remoteAddr":"217.253.***.***","app":"PHP","message":"unlink(): Error Deleting file: 550 \/doc01909420160823154301.pdf: No such file or directory\r\n at \/usr\/local\/www\/nextcloud\/apps\/files_external\/lib\/Lib\/Storage\/FTP.php#98","level":3,"time":"2016-09-09T03:03:49+02:00","method":"DELETE","url":"\/remote.php\/webdav\/Scanner\/doc01909420160823154301.pdf","user":"user.name"}
{"reqId":"DvFb2\/\/yPwGnzfKo3GGw","remoteAddr":"217.253.***.***","app":"no app in context","message":"Invalidating tokens older than 2016-09-08T01:14:40+00:00","level":1,"time":"2016-09-09T03:14:40+02:00","method":"GET","url":"\/cron.php","user":"--"}
Same and curently only user using the desktop client, as the others are fast asleep.
Now again a few minutes later, the file is deleted, no log entry concerning this except the above. And the file test.txt still doesn’t show.
