I have a nextcloud instance running on docker, I extended the original nextcloud:apache using the full Dockerfile example. Nothing has been changed on those two files.
I did this so cron could run on the same container as the main Nextcloud app.
The problem: Each time cron comes do what it has to do, it also changes the IDs of files in folders that are mounted as external (Local). This breaks shared links…
And this is how I have setup my docker-compose.yml:
version: '3'
services:
nc-db:
image: mariadb:10.5
restart: always
volumes:
- db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=SomePassword
env_file:
- db.env
networks:
traefik:
nc-redis:
image: redis:alpine
restart: always
networks:
traefik:
nc-app:
image: nextcloud:me
restart: always
dns: 192.168.96.1
volumes:
- nextcloud:/var/www/html
- /mnt/md0/share1:/var/www/html/data/share1
- /mnt/md0/share2:/var/www/html/data/share2
- /mnt/md0/share3:/var/www/html/data/share3
environment:
- MYSQL_HOST=nc-db
- REDIS_HOST=nc-redis
- NEXTCLOUD_TRUSTED_DOMAIN=cloud.example.com
- TRUSTED_PROXIES=192.168.96.5
- PHP_MEMORY_LIMIT=4G
- NEXTCLOUD_UPDATE=1
- PHP_UPLOAD_LIMIT=8G
- PHP_MEMORY_LIMIT=8G
env_file:
- db.env
depends_on:
- nc-db
- nc-redis
networks:
traefik:
labels:
- traefik.enable=true
- traefik.http.routers.cloud.rule=Host(`cloud.example.com`)
- traefik.http.routers.cloud.tls=true
- traefik.http.routers.cloud.tls.certresolver=le
- traefik.http.services.cloud.loadbalancer.server.port=80
- traefik.http.routers.cloud.service=cloud
- traefik.http.routers.cloud.entrypoints=websecure
- traefik.docker.network=traefik
- traefik.http.routers.cloud-http.entrypoints=web
- traefik.http.routers.cloud-http.rule=Host(`cloud.example.com`)
- traefik.http.routers.cloud-http.middlewares=https-redirect
- traefik.http.middlewares.https-redirect.redirectscheme.scheme=https
- traefik.http.middlewares.https-redirect.redirectscheme.permanent=true
volumes:
db:
nextcloud:
networks:
traefik:
external: true
Has anyone ever encountered this issue? Is it a config problem or a bug?
Thank you
