@Timeraider have a look at the last replies on the AIO issue ticket. There is a way to make it persistent.
Thank you @szaimen
Sebastian
Thank you @szaimen
Sebastian
Morning @gehkah,
Not sure, why you deleted your post but I got the email version of it, so I’ll answer it anyways.
The mail app ONLY supports IMAP/SMTP, I have put in a feature request to change this, but I wouldn’t hold my breath on this getting changed anytime soon, what my app does is pull the auto discovery information and uses that information to configure the mail app.
So if your system does not have auto discovery setup properly or IMAP/SMTP is blocked or disabled then there is nothing that can be done.
Sebastian
Dear Sebastian
I’m so sorry I did bother you. Yes, I did find out while I was reading the details on the github page. Thats why I deleted my post then.
So everything is working, besides I just wanted to configure the mail app with my exchange account (for data privacy, I did disable imap/smtp on Exchange 2019). So no need for me.
Background of my wandering: searched for “nextcloud features” → did read the “nextcloud exchange beta phase” → did google for that feature → found your github → gave it a try → misunderstood the complete project
I am really really sorry for the circumstances, but wanted to thank you, having the time answering anyway
Best Regards, Greg
No worries, all good.
Sebastian
Hello, Sebastian!
Thanks for your app!
When using the application, the following error appears in my logs:
Exception
Exception: Remote Error: ErrorInvalidPropertySet - Set action is invalid for property. in /var/www/nextcloud/apps/integration_ews/lib/Service/Remote/RemoteCommonService.php:1006 Stack trace: #0 /var/www/nextcloud/apps/integration_ews/lib/Service/Remote/RemoteEventsService.php(1073): OCA\EWS\Service\Remote\RemoteCommonService->updateItem() #1 /var/www/nextcloud/apps/integration_ews/lib/Service/EventsService.php(446): OCA\EWS\Service\Remote\RemoteEventsService->updateCollectionItem() #2 /var/www/nextcloud/apps/integration_ews/lib/Service/EventsService.php(195): OCA\EWS\Service\EventsService->harmonizeLocalAltered() #3 /var/www/nextcloud/apps/integration_ews/lib/Service/HarmonizationService.php(210): OCA\EWS\Service\EventsService->performHarmonization() #4 /var/www/nextcloud/apps/integration_ews/lib/Tasks/HarmonizationLauncher.php(102): OCA\EWS\Service\HarmonizationService->performHarmonization() #5 /var/www/nextcloud/lib/public/BackgroundJob/Job.php(81): OCA\EWS\Tasks\HarmonizationLauncher->run() #6 /var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php(102): OCP\BackgroundJob\Job->start() #7 /var/www/nextcloud/lib/public/BackgroundJob/TimedJob.php(92): OCP\BackgroundJob\TimedJob->start() #8 /var/www/nextcloud/cron.php(152): OCP\BackgroundJob\TimedJob->execute() #9 {main}
Harmonization launcher encountered an error while harmonizing for <USER>
I set the settings to sync one calendar
Please tell me how to fix it?
My configuration:
OS: ubuntu 22.04
PHP: 8.1.2
Nextcloud: 28.0.3
integration_ews: 1.0.37 passive mode
MS Exchange: 2019
Morning @X3PPY,
Looks like the app is trying to update an event but Exchange does not like the property that is being updated.
I would need to see the Transport log for the action to see which property it is.
Sebastian
Just discovered your app, I’m loving it. I have connected all our users via their emails. And syncing manually works amazing. I’m just struggling to get autosync working. The started sync will update to the last time the update started but the finished sync doesn’t update (and no changes made to calendar) unless I manually click the “Sync” button. Any help would be amazing. (Maybe I missed something). PHP version 8.2.21 Nextcloud version 29.0.3
Hello together,
I am searching for a MS365 ExchangeOnline Connector.
I want to build a central Hub for our Users.
Can I use the Nextcloud with this EWS Extension as a Mail Client for ExchangeOnline?
Access to Mails, Contacts and Calendar?
Regards Arthur
No. According to the description it only synchronizes calendars and contacts: GitHub - ksainc/integration_ews: Nextcloud EWS Connector (Exchange Web Services)
In order to use the Nextcloud Mail Client with Exchange Online you need to connect it via SMTP/IMAP.
